Can't change Input Monitoring Mode setting?
Posted: Sat Jun 20, 2009 1:40 pm
by Chao
I am using Dp 6 with Metric Halo ULN2 now. I want to change the "Input Monitoring Mode" setting (Setup> Configure Audio System> Input Monitoring Mode>.....)to "Direct hardware playthrough", but it is on " Monitor record-enabled track through effects" mode which can't be changed.
Looks like the Direct hardware playthrough only works with MOTU's own audio interfaces. Is there anyway to get the job done?
Any idea? Thanks!
Re: Can't change Input Monitoring Mode setting?
Posted: Sat Jun 20, 2009 9:01 pm
by Tritonemusic
Chao wrote:Looks like the Direct hardware playthrough only works with MOTU's own audio interfaces.
That is correct.
Posted: Sat Jun 20, 2009 10:15 pm
by boraymond
Not quite, it works with my M-Audio FW 1814
Posted: Sun Jun 21, 2009 4:20 pm
by Mr_Clifford
Generally for non-MOTU audio interfaces, you turn the input monitoring to 'off', then use the software control panel that comes with your audio interface to route a latency-free signal of your input to your speakers. Depending on the interface it might be basic or it could be a complete virtual mixer like with the RME cards.
