Is Mach Five 2 working stable in 64 bit?
Posted: Mon Jun 08, 2009 2:29 pm
by bobbybland
Hello,
Is Mach Five working stable in 64 bit?
Would be running in x64 Vista/Win 7,is anyone running this setup successful?
Thanks for any help you can offer....
Re: Is Mach Five 2 working stable in 64 bit?
Posted: Tue Jun 09, 2009 5:35 pm
by bobbybland
Anyone using it in either Vista64 or Win7 64,care to say how the performance is on 64 bit? Thanks in advance..
Posted: Tue Jun 23, 2009 8:01 am
by Red_Camel
hey bobbybland,
I've try MachFive v2 with Vista Ultimate 64 > Stand-alone mode works fine but still with the usual quirks that can 'cause one to loose confidence in the tool.(ie, crashing when you've got inspiration and momentum going).
Running it in Reaper v2 64-bit version doesn't work. It cannot be detected so am not sure what the 64-bit hype is all about. 32-bit plugin works fine in Reaper v2 but I have not got a chance to test it with the latest v3 yet. Hope that helps out a bit.
Posted: Tue Jun 23, 2009 12:28 pm
by bobbybland
Thanks Red. .I ended up buying it,and haven't tested it in x64 yet so far in 32 bit on Vista64 it seems to work fine..
Thanks again..
