8pre problem
Jaike
8pre problem
Post by Jaike »
Hi all,
This is my first post, unfortunately to ask for help... Thanks in advance for any advice!
I've been using MOTU interfaces (828 MKII and an 8 pre) for about a year, never had a problem, great results, all good.
I use them in conjunction with a MacBook Pro and Logic 8.
Today I've run into a problem with the 8 pre:
- it switches on fine, it receives audio signal fine
- within Logic (and the MOTU Audio Setup), it shows up fine; Logic receives the audio signal from the interface, and you can record sound. In Logic, the output is set to 1-2, and there is signal there is signal in the Master VUs.
BUT, there is no sound from the interface: nothing in the head phones, nothing on Output 1-2, audio or click.
I've tried rebooting, tried the interface in Waveburner, same issue... I don't think it's coming from the Mac or Logic because everything seems to working as usual. Could the output have fried on the interface?
Like I said, any help would be great.
Cheers,
Jaike.
RDBDR
Re: 8pre problem
Post by RDBDR »
Hi Jaike,
I have the same problem with my 8pre. I've found that if I just turned the MAIN VOLUME knob on the front panel of the 8pre a little bit, everything magically starts working again. I'm interested to see if this magic works for you as well.
Good luck,
---rick
2.8 GHz 8-Core Mac Pro | 18GB RAM | OS X 10.5.5 | DP 6.01
2.4 GHz 2-Core MacBook Pro | 4GB RAM | OS X 10.4.9 | DP 5.11
MOTU 8 Pre | BLM Traveler | 896-mk3 | M-Audio Octane | MicroTrack II
2 ea: QTC 50 | AKG C414B-XLS | RØDE NT2-A & NT5 | DPA 4061 | SP LSD2
