Can The UltraLite MK3 Be Used As A Standalone Effects Unit?
HotShot
Post by HotShot »
Hi all:
I'm wondering if the UltraLie mk3 can be used as a standalone effects unit.
I'm trying to test the external insert plug in in SONAR to see if it works correctly using external effects gear.
Does anyone know if I can use this unit in standalone mode just to use the EQ or Reverb as I have my Delta 1010LT as the audiointerface in SONAR?
Thanks for any help.
May a song always touch you in a possitive way!
SONAR X1a Producer
Windows 7 Pro 64-Bit
Intel Core i7 920, Gigabyte EX58-UD5, ATI Radeon HD 5770
MOTU UltraLite MK3, Delta 1010LT, KeyStation Pro 88, Shure KSM27, 6GB 1600MHz DDR3, 160GB, 350 GB 7200rpm HDDs, QSC K12s, Numark DDS80
dare
Re: Can The UltraLite MK3 Be Used As A Standalone Effects Unit?
Post by dare »
yes, it can :)
