Superior Drummer, how to save your drum setup?
Posted: Wed Aug 10, 2005 6:27 am
by RockNRoll
Hi there,
Using superior drummer with DP 4.6 via rewire. Is it normal for your drum setup to reset itself everytime you close and then re-open a session leaving you to have to go through the routine of setting up your drums again? Is there a way to save your drum setup so you don't have to rebuild your drum set everytime? Thanks for the tips.
Re: Superior Drummer, how to save your drum setup?
Posted: Wed Aug 10, 2005 7:27 am
by nixon72
Yes it is normal. As soon as the rewire chain is broken, it shuts down. Save your kit early and often.
Posted: Wed Aug 10, 2005 9:49 am
by thealtsax
Hi, DFH superior works so much better as audio unit multichannel with DP 4.6. Try it :)
