6.0.2 bounce to disk error?
Posted: Sat Feb 28, 2009 9:30 am
by Sonormuseum
When trying to bounce a very small project to disk I get this error message no matter which option I use:
Mas, 1 error reported by core audio plugin/Core Audio support code: /Users/dpdev/AutoBuild/DP/DP6_02_Branch/MAS/Plugi [-35]
Has anyone else experienced this? This is my first project & bounce attempt since installing the 6.0.2 patch.
I'm going to reinstall 6.0.1 and see if that fixes it.
Thanks,
Scott
Re: 6.0.2 bounce to disk error?
Posted: Sat Feb 28, 2009 9:55 am
by Sonormuseum
It didn't.
Posted: Sat Feb 28, 2009 10:33 am
by James Steele
Did you install any 3rd party plugs in the time since your last successful bounce to disk? I ask this because I had a similar if not same area last night and it happened after I installed the Novation V Synth demo. I quit DP, removed the plug-in from the Components folder, and I was able to bounce to disk. If you have installed a third party plug recently, try disabling it in the Audio Plug-Ins preferences in DP, then restart MAS and try the bounce again. Good luck!
Posted: Sat Feb 28, 2009 11:19 am
by Sonormuseum
Yes I did about a month ago. I couldn't tell you the name of it - some sort of freeware metering plug that would show the EQ curve in realtime. Kinda handy if you're getting too much of something from a track. That's the only aftermarket plug I've added ever.
As it turns out I simply deleted the app and anything else I could find in the library that looked associated with MOTU or Digital Performer and reinstalled 6.0.1 yet again. It's working fine for the time being, though I did lose someof the sequences I'd previously added to that project. ??!! No biggie. Each sequence is no more than 2 minutes long and I can redo them easily enough.
I'll try reinstalling the .2 patch later.
Live and learn.
Scott
Posted: Thu Mar 05, 2009 9:48 pm
by monkey man
Was it the Blue Cat FreqAnalyst plug, Scott? I've experienced graphic glitches lately but installed a bunch of freeware at once, so at this stage I'm clueless as to the possible cause.
FWIW, the plug appears to be awesome for a freebie spectrum analyzer:
http://www.dontcrack.com/freeware/downl ... eqAnalyst/
Posted: Sat Mar 07, 2009 7:13 pm
by scooter
I had problems with this happening when I converted a DP5 project to DP6 and then tried to bounce. Didn't work. Even if I loaded a DP5 seq. into DP6. If you start from a new DP6 session then you won't have any bounce problems. I don't know if this applies to your specific situation.
scooter
