2408 Mk3 not recognized by my PC.
Posted: Fri Jan 16, 2009 4:55 pm
Windows Vista 32bit
Nvidia 680i
Intel Quad 2.4ghz
2gb ram
geforce 8800gtx graphics card
I've been troubleshooting and searching all day, but I can't get my 2408 to be recognized by my pc. I installed the PCI-424 drivers before installing the card. Then I installed the card, and it seems to be recognized ok. I'm not entirely sure how to check. In device manager I can see the drivers under sound devices, and it seems that they are working properly. However, the 2408 is not recognized by the computer. I have tried all 4 firewire slots, and 2 firewire cables. I also installed the "Firewire/USB2" drivers from the motu site, assuming they were needed for the 424 to speak to the 2408, but that didn't help either. I do not have the install disk. I'm an FOH engineer, and we have had this unit sitting around at the shop for a long time, and now we are starting to do post mixes, so I want to get it running. But I haven't been able to locate the install disk. I figured the drivers online would be all I needed, but perhaps there are drivers on the disk that are needed as well. On the "Cakewalk and MOTU Audio" article on motu.com, it says, "When you run the MOTU Core installer you will have the option to install the ASIO Driver as well as the Wave Driver. Install the Wave Driver." This step is not an option with the 424 or firewire driver installs. So perhaps the install disk is a must? I do plan on using it with Sonar, but just getting it to pop up as a playback device in vista is my primary concern at the moment.
Any help, or troubleshooting tips would be welcome.
Nvidia 680i
Intel Quad 2.4ghz
2gb ram
