Traveler and 4 pin FW?
Posted: Thu Jan 01, 2009 4:55 pm
by Farview
Will the Traveler, or any other Motu firewire interface work with the 4 pin mini firewire connector? I'm assuming that it can't be buss powered, but will it work?
Re: Traveler and 4 pin FW?
Posted: Fri Jan 02, 2009 8:23 am
by TechSupport
Please check out this tech note:
4-pin or Firewire 800 Firewire with MOTU Firewire Interface
Also, regarding bus power:
I'm having trouble powering my Traveler or UltraLite via FireWire
(Note that this isn't a MOTU-specific limitation — the pins which are not present in a 4-pin FW cable are the ones that provide power.)
Posted: Fri Jan 02, 2009 9:56 am
by 1nput0utput
You're right. It will work fine but you'll have to use a DC power supply since the four-pin FireWire connector doesn't supply power.
Posted: Fri Jan 02, 2009 6:35 pm
by Farview
Great! Thank you very much.
