Wuz up with the monitoring tab in the cue mix fx
Posted: Wed Dec 17, 2008 7:03 pm
by ALF1NER
Hey yall wuz up with the monitoring tab in the outputs section of the cue mix fx software? if the monitoring tab in the outputs section is not on the music blast loud as ••••! it almost blew out my monitors, my cans, and my eardrums. Does that happen to any1? let me know what i can do to fix this problem. Thanks.
Re: Wuz up with the monitoring tab in the cue mix fx
Posted: Thu Dec 18, 2008 4:57 am
by woodshedder
Just to let you know, the same thing happened to me! Bugged me for a while, and decided to look into it. Probably somebody with more experiance will chime in!
Posted: Thu Dec 18, 2008 6:34 am
by 1nput0utput
The monitor button for each output pair in the Outputs tab determines whether that output pair is part of the monitor group. They monitor group outputs are scaled by the master volume control. Outputs that are not in the monitor group are not scaled. When an output is not in the monitor group, audio passes to it with no additional attenuation.
Posted: Thu Dec 18, 2008 6:47 am
by Jelle
well, that clears things up for me :)
Just got my new ultralite, and the cuemix software certainly takes some time to get used to...
Posted: Fri Dec 19, 2008 1:23 pm
by frankmcma
Is there a way to turn down another section of the program to avoid this? I am just afraid I am going to accidentally toggle off that monitor button (its already happened once and it bla-ss-ted) and blow up my speakers.
Any way to set perhaps a section of the program to not blast if the monitor is accidentally clicked?
Frank
Posted: Sat Dec 20, 2008 9:30 am
by frankmcma
any ideas?
Posted: Sat Dec 20, 2008 10:22 pm
by Klaus
You could get a passive balanced xlr/xlr attenuator, or make one yourself, just take care the
load isn't to lo, i.e.5 kOhms would be ok, but just inserted before your poweramp / act. speakers input
Take care
Klaus
