This may just be dumb pilot error, but with the latest version of cuemix, every time I try to increase the trim settings of a channel on my Ultralite it stays there for about 3 seconds, and then resets to zero. This is driving me nuts.
Please help if you can. I believe I downloaded the latest cuemix version, and I did not have this problem with the prior version, which had a different GUI by the way.
Thanks in advance.
cuemix resets trim settings on UltraLite
Re: cuemix resets trim settings on UltraLite
Same deal here.
On another thread, someone commented that it's a known issue and it is being worked on.
Another issue is the window sizing...if you make all the channels stereo, the window shrinks to size.
However, making the channels mono again doesn't enlarge the window again...even on restart. You're stuck with having to use the horizontal scroll, because the lower right window resize toggle doesn't work either.
I found a workaround...
Go to: "C:\Documents and Settings\<computer user>\Local Settings\Application Data\MOTU\CueMix FX\Preferences.xml"
Open the "preferences.xml" file in Notepad and change the value to 10 in the following line:
<SINT name="ConsoleWindowWidth" value="7"/>
Save and restart Cuemix FX.
It will open up the Cuemix UI again.
(Make a shortcut to the prefs file as you'll have to go back to it whenever you have to max the interface again)
QuBe.
QuBe.
