Best way to use DP 5.13 and 6.01 on same system?
hrw
Post by hrw »
for maximum reliablity in both progs?
is there any tips about where certain files or MAS plugin's should go etc? Partitioning?
thanks in advance.
h.
Computer/s: OSX 10.8.3
2 x 2.66 GHz Mac Pro Quad-Core Intel Xeon w/ 16GB RAM,
DAW:DP8.05
Hardware: Apogee Duet
VI's/Plug-ins:
Kontakt 5.1, EW PLAY Libraries and a
million others.
joelmusic
Re: Best way to use DP 5.13 and 6.01 on same system?
Post by joelmusic »
I've been using both versions and they both seem to work fine for MIDI and audio. I'm not sure about VIs and FX - how they are handled - I imagine you can access them from both? Anyway, no problems over here for what I'm doing.
kassonica
Post by kassonica »
I've been running both on the same system without any problems although I haven't opened 5.13 in a LOOOOOOOONG time :shock:
Dwetmaster
Post by Dwetmaster »
Regurlarly work with both version no problem. I still find it weird that they share the preference file. Some window sets I've done in DP6 can be recalled in DP5 even if some of the new windows don't exist.
EMRR
Post by EMRR »
I may go there also. I'm somewhat between projects (ha!), and the ones still 'in route' in 5.13 shouldn't suffer (famous last words) from any 'service disruptions' caused by new work in 6.01. May be my best opening for awhile.
Doug Williams
Tape Op issue 73
DP 11.34
Studio M1 Max OS12.7.6
MOTU 16A and Monitor 8
slab
Post by slab »
I like to work only with 6.0.1, it rocks for me!!
hrw
Post by hrw »
slab wrote:I like to work only with 6.0.1, it rocks for me!!
Thanks slab... no need to rub it in though...
just kidding. Happy for ya.
h
DAW:DP8.05
VI's/Plug-ins:
million others.
