Page 1 of 2
DP 5.1 and Atmosphere Problem
Posted: Mon Aug 18, 2008 1:07 pm
by MusicMan_08
I am running Digital Performer 5.1. When I try to create a VI track with Atmosphere it freezes up and then crashes DP. Is anyone else having this problem?
Any help would be greatly appreciated!
Posted: Mon Aug 18, 2008 1:16 pm
by Matcher
First I'd recommend upgrading to the latest OSX, Atmosphere, and DP 5.13.
Posted: Mon Aug 18, 2008 1:21 pm
by npatton
Atmosphere also required a wrapper to run in DP 5. Available at Spectrasonics website, I'm pretty sure.
Posted: Mon Aug 18, 2008 1:22 pm
by MusicMan_08
I just upgraded to Leopard. I will try to upgrade to DP 5.13 tonight and also Atmosphere if there is an upgrade and see what that does.
Thanks.
Posted: Mon Aug 18, 2008 1:55 pm
by buzzsmith
Does this help?
http://www.spectrasonics.net/news/intel ... onics.html
In my PPC system (see sig) I have to use the VST wrapper version for Atmosphere to work. Trilogy and Stylus seem to be OK without the wrapper.
Buzzy
Posted: Mon Aug 18, 2008 2:26 pm
by MusicMan_08
I have a Power Mac G5 which isn't an intel processor, so I don't think that helps me.. But thanks.
Posted: Mon Aug 18, 2008 5:27 pm
by MusicMan_08
OK. I updated DP to DP 5.13. I Updated Atmosphere to 1.2.4. And Atmosphere still crashes DP when I try to open it... I'm not sure what to do, except get DP 6.
Posted: Tue Aug 19, 2008 12:08 am
by Matcher
You can also ask Spectrasonics and MOTU tech support. Do you have any other host apps on your system to test if Atmosphere works with them? Has Atmosphere worked ok with DP at some point?
Posted: Tue Aug 19, 2008 5:35 am
by buzzsmith
MusicMan_08 wrote:I have a Power Mac G5 which isn't an intel processor, so I don't think that helps me.. But thanks.
I have a Power Mac G4 and with the VST wrapper it works fine. In my case, when I select "Add Instrument" it shows (amongst all the other VI's) 2 versions of Atmosphere. I load the one earmarked VST and I'm OK...the non VST version will not work on my system. It doesn't crash DP, it just doesn't work at all.
Buzzy
Posted: Tue Aug 19, 2008 2:50 pm
by MusicMan_08
Yes, Atmosphere worked perfectly when I was running DP 4.6. I am using AU though.. Maybe I should try VST with that wrapper and see if that works...
I have MOTU Symphonic Instrument and it is working fine.
Use Rax for Atmosphere PPC without wrapper
Posted: Wed Aug 20, 2008 10:44 pm
by jesus chrysler
[quote="MusicMan_08"]Yes, Atmosphere worked perfectly when I was running DP 4.6. I am using AU though.. Maybe I should try VST with that wrapper and see if that works...
[/quote]
I use Atmosphere without the wrapper for intel Macs by loading it into Rax, which is worth it, since that stupid free wrapper has wasted so much time with some users (like me). Just read the spectrasonics list, and you'll get to enjoy all the rancor. Rax is very useful, too, for other things.
http://www.audiofile-engineering.com/rax/
Rax demo lets you load 1 AU, too, and doesn't expire, so if Atmosphere is your 1 AU, it's just as free as the wrapper.
jc
Posted: Thu Aug 21, 2008 3:54 am
by Matcher
Wow, thanks for the tip!
Posted: Thu Aug 21, 2008 7:06 am
by MusicMan_08
Thanks a lot! I'll be sure and try that.
Here's a quick question:
I have about 7 or 8 projects that I created with DP 4.6 and they use the atmosphere plug-in. Now, when I open those projects in DP 5.13, it crashes DP. I'm afraid that I've lost all of that work and composed music..... :(
Any ideas?
Posted: Thu Aug 21, 2008 7:48 am
by daveyboy
I'll have to check out the Rax thing. When I was on ppc and went to leopard Atmosphere and trilogy quit working all together so I bought the vst wrapper by audioease.
Posted: Thu Aug 21, 2008 8:17 am
by daveyboy
Got Atmophere loaded in Rax (demo mode). It's actually the intel wrapper version but it loaded fast and is playing perfectly. Can trigger it from within DP6 no problem. How are you getting audio back into DP? I'm trying to use soundflower but it's not working for some reason right now. Is there another way? Thanks for any help.
