Page 1 of 2
Dp 5.11 with BFD 2
Posted: Thu Aug 14, 2008 8:39 pm
by Cromag123
I just got BFD 2, How do you use it with Digital performer? (5.11)
Do I have to have both programs running at the same time?
Any feedback will be greatly appreciated. :?
Posted: Thu Aug 14, 2008 9:02 pm
by climber
well.... have you read any of the docs? it will run inside DP as a VI OR it can run stand alone.
Posted: Thu Aug 14, 2008 9:31 pm
by Cromag123
climber wrote:well.... have you read any of the docs? it will run inside DP as a VI OR it can run stand alone.
Yes, it says it will run inside dp, but it Doesn't say how.
Posted: Fri Aug 15, 2008 2:11 am
by Tritonemusic
Of course it does. It's in the BFD2 Manual.pdf on page 185. Read the section called "Using BFD2 as an AU plugin in Digital Performer."
Posted: Fri Aug 15, 2008 5:06 am
by climber
BTW it runs in exactly the same manner as any other VI. and that info is in the DP manual.
Posted: Fri Aug 15, 2008 11:41 am
by Cromag123
My bfd manual has only 180 pages.
Posted: Fri Aug 15, 2008 9:21 pm
by Tritonemusic
Cromag123 wrote:
666 wrote:
Cromag123 wrote: Yes, it says it will run inside dp, but it Doesn't say how.
Okay...
Have you tried searching for the term "Digital Performer" in your manual?
You're going to have to put some effort into it if you want to get something out of it.
Posted: Fri Aug 15, 2008 11:52 pm
by Cromag123
Okay...
You're going to have to put some effort into it if you want to get something out of it.[/quote]
Effort? That's funny. I've been pulling my hair out :? I did find some helpful tutorials on the fxpansion website and some other pdf manuals.
I have an intel mac mini with only 1 gig of ram, BFD sucks that up like a $2 •••••.....
If I use more than a hi hat, kick, & snare at the same time my cpu goes haywire.
Posted: Sat Aug 16, 2008 12:31 am
by stephentayler
Maybe there is more than one manual? The pdf for download at FXPansion's site does only have 180 pages and no mention of Digital Performer
kind regards
Stephen
Posted: Sat Aug 16, 2008 12:32 am
by Tritonemusic
That's an important point you make. 1 GB of RAM really isn't very much, considering you have to run OS X, DP, and BFD2 at the same time.
How much RAM will fit into your Intel MacMini? If you can, max it out to full capacity.
If you're having a problem coming up with a BFD2 Template for DP, FXPansion's website has a template available for download (search their forum).
Also, turning off the built-in effects can make a huge difference. Even though I've never tried it, switching to 16-bit mode is suppose to make somewhat of a difference. Consider lowering the numbers of layers you have for your drum sets (again, I haven't tried it for myself).
Other than that, I don't really know what to say except for good luck.
Posted: Sat Aug 16, 2008 12:41 am
by Tritonemusic
stephentayler wrote:Maybe there is more than one manual? The pdf for download at FXPansion's site does only have 180 pages and no mention of Digital Performer
I'm accessing the manual by clicking the "question mark" (Help) icon in the upper right-hand corner of BFD2's interface. Then, I select "Launch PDF Manual." It's 188 pages long.
I'm using BFD2 v2.0.4 build 17. Maybe we have different versions of BFD2?
Posted: Sat Aug 16, 2008 10:09 am
by Cromag123
Thanks, I can put 2 gigs of memory in my mini, but it ain't easy. They didn't make it easily serviceable. I will try turning off the effects in BFD, I only use the the effects in DP anyway.
Posted: Sat Aug 16, 2008 10:43 am
by Cromag123
I have since downloaded updates from the fxpansion website, the manual now has 188 pages :P
Posted: Sat Aug 16, 2008 11:00 am
by Tritonemusic
Hey, that's great, Cromag.
Keep us posted on your progress.
Posted: Sat Aug 16, 2008 5:36 pm
by Cromag123
Thanks, will do.
