simple 828 mk3 test
Posted: Wed Jul 16, 2008 3:35 am
tried a simple test: recorded a MIDI channel (input coming from a waldorf synth, playing a bass drum pattern) into one 48khz/24bit audio channel in cubase, asio direct monitoring active.
when trying to play back both the audio and the MIDI at the same time, its clearly obvious that there is a small delay between both...
i though that the delay was only possible to occur in monitoring, but not at recording/playback?? its even stated in the 828 mk3 manual somewhere...
