Page 1 of 2
896mk3 track naming
Posted: Mon Jul 07, 2008 1:51 pm
by Klaus
doesn't work...
but works with CueMix FX for Mac...
Anybody knows a workaround to get the track names changed in CueMix FX / Windows ?
Klaus
Posted: Mon Jul 07, 2008 3:09 pm
by 1nput0utput
Windows doesn't support audio I/O port naming, which is why you can change the I/O port names in CueMix FX. Mac OS X does support this feature.
Posted: Tue Jul 08, 2008 12:04 am
by Klaus
Thanks for reply ;-)
So it's up to MotU to program it
> inside CueMix FX, not ?
I have to use a Win laptop for remote and don't want to take another
box ( Mac ) on the road...
Best
Klaus
Posted: Tue Jul 08, 2008 12:14 am
by Klaus
MotU Suggestion page creates error...
Klaus
Posted: Tue Jul 08, 2008 4:18 am
by 1nput0utput
Klaus wrote:Thanks for reply ;-)
No. Windows can only display the audio I/O port names that are published to the OS by the interface driver. Mac OS X has a feature where it can display either the port names published by the driver or custom names specified by the user. In order for this to work under Windows, Microsoft would have to add such a feature.
Posted: Tue Jul 08, 2008 8:44 am
by Klaus
Sorry to ask,
couldn't this be an option in the driver settings ?
Klaus
Posted: Thu Jul 10, 2008 4:30 pm
by Brad McGowan
This is the most retarded thing ever. How hard is it for MOTU to just put a little text box into the CueMixFX GUI next to each channel that allows the user to write whatever text they want? Who cares if it's linked to the audio driver ports? It doesn't have to be this complicated.
Also why does MOTU think that it's a good idea to limit the horizontal size of the new CueMix window? Are they still using 17" CRT monitors in their office?
Brad
Posted: Thu Jul 10, 2008 8:23 pm
by CSprague
If you look close at the lower right bottom, and are lucky, there is a drag point, I've managed to enlarge it to include all of the channels.
Posted: Thu Jul 10, 2008 10:25 pm
by Klaus
CSprague wrote:If you look close at the lower right bottom, and are lucky, there is a drag point, I've managed to enlarge it to include all of the channels.
not me...
it expands only to a certain size...
I am using additional Adat inputs...
Please MotU
Klaus
Posted: Mon Jul 14, 2008 4:35 pm
by Brad McGowan
Yep, you can only get about 10 inputs to show at a time. It's not really good for a pro user who is trying to see what's going on from across the control room.
Brad
Posted: Mon Jul 14, 2008 6:08 pm
by CSprague
Nope: I normally turn off what is not used but for this test I activated all the ADAT channels A&B. I've got a Wide screen monitor and managed to pull them all out. Full access
Posted: Tue Jul 15, 2008 1:12 am
by Klaus
I'm not a Windows spezi, but maybe it depends on monitor / screensize
Klaus
Posted: Tue Jul 15, 2008 8:05 am
by peddap
I'm facing the same issue here. Since I use almost every connection incl ADAT A&B and also have five different mixes it's a real confusion. I struggle with this all the time.
I also use the MOTU in my band when we play live and man is it ••••ed up... Try to adjust something quick and at the same time stay focused playing on stage... good luck!
If MOTU can find a way around this I'm gonna get rid of it.
So, PLEASE all MOTU representants!!! do something for us to be able to put an label on each channel. :!: :!: :!:
Peter
Posted: Tue Jul 15, 2008 3:27 pm
by Klaus
I urge everybody ( CueMix FX Windows users ) to go to
http://www.motu.com/other/feedback/suggestions
and suggest it.
Please MotU
Best
Klaus
Posted: Tue Jul 15, 2008 6:39 pm
by pcournoyer
You bet, I have done mine!
Surprising how you can make such a complex piece of gear and leave out fundamental stuff like window resize and channel custom label.
The fact that you can rename the signal on the MAC is still not enough in my mind...you want BOTH the signal name as it is on the equipment for easy connection PLUS a custom label to remember what you are doing with this input/output.
