Processor Overload Error While Recording (Help Please)
Posted: Sat Jun 14, 2008 9:11 pm
by timothyclee
I've been having some issues with DP lately and am in need of some help. I've got 3x8pre's hooked up to my macbook pro and am trying to record some live shows. I have only Mac OSX leapord installed and DP no other software is loaded, this is a remote recording only laptop. No plugins besides the stock DP stuff...anyways midway through recording I get an error message that says my processor is overloaded and some samples may have been dropped. If I lesten back I get static in all the tracks. I don't know why the processor would be overloaded??? I'm not running any plugins and am just tracking to disc I'll import it into my studio mac after the gig.
Thanks for your help.
Tim
Posted: Sun Jun 15, 2008 6:59 am
by monkey man
Hey Tim,
You might try raising the buffer size to 1024.
Should this not kill the issue, you could disable the alert pop-up in DP's prefs, make a test recording or two, noting where you hear the pops, and checking that upon playback they're not there.
FWIW, the alert's been known to be conservative; it's indicative of MOTU's approach regarding the sanctity of recorded audio.
Hope this helps.
Posted: Sun Jun 15, 2008 7:14 am
by richardein
Your eqp't list does not include an external hard drive. If you're not doing so, you should be recording to one. Get at least a 7200 firewire drive. I don't know where in the chain it is supposed to go, but the 8 pre manual will probably have some info about that.
Also, if you're getting static, you may have clocking issues. Be sure the 8 pres are all synced to the same clock. I"m not sure, but you may need a separate master clock device with a 3-interface setup.
Be sure to turn off all networking software and to max out your RAM.
hth
Re: Processor Overload Error While Recording (Help Please)
Posted: Sun Jun 15, 2008 7:36 am
by Aramis
Hello ,
I am betting on clocks issue here . Can you elaborate on how are all your audio interfaces interconnected ? Do you have a world clock coax cable properly terminated between all of your audio boxes ?
Aramis
timothyclee wrote:I've been having some issues with DP lately and am in need of some help. I've got 3x8pre's hooked up to my macbook pro and am trying to record some live shows. I have only Mac OSX leapord installed and DP no other software is loaded, this is a remote recording only laptop. No plugins besides the stock DP stuff...anyways midway through recording I get an error message that says my processor is overloaded and some samples may have been dropped. If I lesten back I get static in all the tracks. I don't know why the processor would be overloaded??? I'm not running any plugins and am just tracking to disc I'll import it into my studio mac after the gig.
Tim
Posted: Sun Jun 15, 2008 8:01 am
by Aramis
Hello again !
Here is a link to a little graphic showing how you should br connected in between all those boxes .
http://gallery.mac.com/marceljacques1#100172
Aramis
P.S. There are good examples in the MOTU hardware manuals ?
Tim
Posted: Sun Jun 15, 2008 9:09 am
by supersonic
Turn DashBoard Off, as well as Airport
