Live 7 & Digital Perfomer 5 [MIDI]
Guruluku
Post by Guruluku »
Hi! Im using Digital Performer as host application connected to Ableton Live via rewire.
I would like to know if it's posible to use a MIDI track in Ableton Live to trigger an instrument in Digital Performer.
jeepbird
Post by jeepbird »
no, I don't think so. We can't trigger host instrument from a rewire slave.
MacOS 10.14.6 / DP10.11 & DP9.52 + VEP Pro/ Macbook Pro 2018/ Benchmark DAC1 USB / RME FireFace UCX / Adam A7 / XV-3080
96khz
Post by 96khz »
Maybe thru the IAC Driver? In DP go to Setup/Interapplication MIDI and create an input port. I think it will then become a valid MIDI output in Live...
Guruluku
Post by Guruluku »
Thanks both! Will try it.
c0mp0ser
Post by c0mp0ser »
Is it possible to do the reverse?
How do you trigger audio loops in LIVE from a DP MIDI track?
I have live running as a slave. I used to be able to do this no problem when LIVE was on a separate computer. But now that it's under rewire I can't seem to configure the MIDI map in LIVE.
Thanks.
