896HD Newbie question
Posted: Sun Apr 20, 2008 4:59 am
by martin7
I'm considering upgrading to the 896HD from my onyx firewire. I'm running a amd 4400 x2 win pro 2gig ram. I've also got a mac book pro 2.6ghz - 4 gig ram. So I need an interface for both and am hoping to find something that can take some of the load off my cpu - especially during mixing where I currently hit the plug in wall all too quickly. Is the 896HD a good choice or are there any others?
thanks,
Martin7
Posted: Sun Apr 20, 2008 9:09 pm
by billruys
If you're hitting the wall during mixing due to plug-in load, how do you think a new audio interface is going to help? It probably won't. That is not what CueMix DSP does. CueMix is great for monitoring inputs when you're recording, but it won't help you during mix down. Also, it routes before the signal hits your computer, so if you're thinking you can somehow monitor your DirectX/VST effets with CueMix during the recording phase and off-load some CPU cycles, you'd be wrong.
If you need a new audio interface that will work on PC and Mac, it's probably a good choice, but don't buy it thinking it will fix your CPU overhead problems.
Maybe you should spend your hard earned cash on a new PC with a quad core CPU first, or pick up something like a UAD-1 card that will offload some CPU if you use the bundled effects instead of native DirectX/VST.
Posted: Mon Apr 21, 2008 12:53 am
by martin7
Thanks. I had a lurking feeling of unease considering these issues. I probably will upgrade my pc cpu. Regarding the 896, I think I would miss the lack of MIDI in/out - Any recommendations?
896 HD
Posted: Sat Jul 19, 2008 8:14 am
by hswin
You might look at the MOTU Ultralite if you didn't any more than 2 microphone inputs. Now if you are using external preamps, that part would not be an issue. The Ultralite has MIDI and SPDIF I/O.
Posted: Wed Jul 30, 2008 6:50 am
by martin7
I'll check that out. Thanks!
Posted: Sat Aug 09, 2008 11:11 pm
by Vim
buy one of the RME FW interfaces instead.
Posted: Tue Aug 12, 2008 11:15 am
by martin7
What, in particular, makes them stand out?
m7
Posted: Tue Aug 12, 2008 11:51 am
by 1nput0utput
martin7 wrote:What, in particular, makes them stand out?
m7
MOTU is obviously better because they have more letters than RME.
Posted: Wed Aug 13, 2008 1:09 am
by martin7
sold...
