Cymbals cutting off too soon
Posted: Fri Apr 18, 2008 1:24 pm
by buzzsmith
Hello, again!
I'm working on 5 MIDI files from a show producer and did not do the sequences. My job is to take his GM stuff and run it through better VI's including Mach Five (1), for recording the vocals soon to the tracks.
Everything's working pretty well, except he has a ride cymbal pattern (jazzy swing) going occasionally.
The cymbals will only play for the duration of his hit (like an eight note [240 ticks], only sounds for that duration)...I know there's a way to tell Mach Five to let the cymbal keep on ringing (without physically going in and editing every one), but I can't find it via a search here or in the Mach Five (1) manual.
I know how to get the open hat to shut off when another hat is triggered, but I'm struggling with these choppy ride cymbals.
What am I missing? :?: A link to another thread is just fine or a page number in the Mach Five 1 manual.
Buzz
P.S. I could switch to BFD if need be for the cymbals, but I'd like to know how to get this done within Mach Five.
EDIT: I think I found it...if you select a particular sample, and raise the D S and R faders within the Amp (and Pan) envelope generator, that seems to eliminate the cut-off problem.
Posted: Fri Apr 18, 2008 2:01 pm
by carrythebanner
Select the cymbal keygroup, open the Sample Info pane ("i" button along the left of the waveform), and change Loop Type to "one shot." Make sure to save the samples afterwards, since Loop Type is a sample-level control.
Posted: Fri Apr 18, 2008 4:46 pm
by buzzsmith
Thanks, ctb...
My workaround seems to be OK, but I'll give your suggestion a shot mañana!
Buzz
