A couple of questions before I start this 828mk3 project. Iam trying to replace an O1V and 5 black box's with the mk3
See
http://www.kc4pe.com/amateurshack.htm
for the setup......
1.- The CD/Disk is not "AutoStart", so I'm not sure where to start within the disk and what the proper sequence is in loading the entire program ... also at what point in the loading sequence do you turn the unit on and when do you plug up the "FireWire cable".... Even if the disk was "AutoLoading", there should have some sort of instruction..
So I need the 1-2-3's in loading the program....???
I have asked someone named .."Magic Dave" for some help but that was over 24 hours ago....
2.- What screen resolution should I use you want...?? Seems it is going to be down around 800/1075 in order to see the printing on the EQ windows...???
3.- I winder where to start on the Reverb setting for the male voice ..wish Motu would of given some starting pts for various apps....
4.- What Icons should be on the screen for the 828..??
5.- Does the screen/template for the control panel stretch..??
Thanks,
-Bill
828mk3 inital Loading.....
