828mkII randomly freezes
Posted: Sat Mar 29, 2008 6:43 am
by kaluchie
My 828mkII FW has started randomly freezing for no apparent reason. I thought it might be a Windows driver problem so I reinstalled the latest version, but it still occurred.
So I tried disconnecting the Firewire cable and just leaving it switched on to test it and it also froze eventually. I'm guessing it must be some sort of hardware fault. Any suggestions of fixes, or should I just return it to Motu?
When it freezes, the clock samplerate light goes out and the main LCD display gets stuck on whatever it's showing at the time. If there's any audio activity on the meters at the time, they also get stuck on that level.
Any help, suggestions appreciated. Thanks.
Posted: Sat Mar 29, 2008 10:53 am
by 1nput0utput
If the problem happens when it's not connected to the computer, then I think the interface is malfunctioning. You should probably contact MOTU.
Posted: Sat Mar 29, 2008 11:03 am
by kaluchie
Yeah, I thought that might be the case. Thanks for the advice.
