828 mkII makes DP crash
Posted: Wed Mar 05, 2008 3:32 pm
by kristupes
I'm running DP 5.12 on my MacBook pro, with samples on an external drive. I use the 818 mkII as my audio interface. It seems to be having some kind of problems because DP has crashed a number of times within just an hour.
When I've used the same interface on my G5 desktop I've had all kinds of issues too, the audio stalls, I can't bounce to disk properly. I don't know if these problems are related or if it is the 828 causing it, but my laptop has been running with no problems when I use an mbox (..!). Any suggestions on what to do?
Posted: Wed Mar 05, 2008 10:43 pm
by jarok
Hi
Try first to reset your 828 to Factory Default Settings.
Here is some 828MkII reset info:
http://www.motu.com/techsupport/technot ... earchterm=
Check also your FireWire or USB cables that are connected to 828. Broken cable can cause troubles.
If that doesn't work you might have to take it to a repair shop.
jarok
