WARNING: Multiple MOTU FW units won't work under WinXP SP2!!
Posted: Tue Nov 27, 2007 6:00 am
I purchased 4 8Pre's only to find that 2 or more would not sync up. I scoured the forum, MOTU Tech Notes, applied or checked every solution I could find recommended, and still no luck. I put in a Techlink w/MOTU last Thursday, but to date have not heard anything.
Yesterday Matt in tech support at Sweetwater, where I purchased the units, called to tell me that MOTU told them they do not support multiple units under Windows XP SP2! They officially support only SP1. I know this sounds crazy since SP2 has been out for quite a long time now, but that is what I was told.
I spent 2 complete days (my Thanksgiving break!) trying to get this system to work. Below is the information I submitted to MOTU in my tech link so you can see that I've tried just about everything.
MTL 13928 ••” Multiple units will not stay in synce on Firewire Last edited by Joseph on 2007/11/26 09:24:13 US/Central
Edit TechLinkUser XXXXX XXXXXX Submitted 11/22/2007 15:30:04
Issue type Hardware (all others) Status Unread Product(s) 8pre Version 3.6.7.4/Hardware v1.0 System information OSWindows XPOS versionSP2CPUAMD X2 4200+/abit AN8 SLIRAM 2 GB
Additional system info: This is the computer configuration I am currently testing on, but have encountered the same issue on 2 other computers with different hardware setups. Also, I have 2 nVidia based 7600 GT video cards in SLI configuration, although I am not running in SLI mode when doing DAW work
Additional information:
Troubleshooting: Installed dedicated Firewire card w/TI chipset. Applied MS hotfix for the WinXP SP2 Firewire slowdown issue. Confirmed that the hotfix was applied in the registry. Disabled 1394 network connections. Tried multiple combinations of Firewire ports on back of 8 Pre's.
Steps to reproduce: Happens randomly, but within minutes of initial sync, oftentimes seconds. The longest I have been able to go without a problem was approx 5 minutes.
Details: I purchased 4 8Pre's to make a live recording system of 32 tracks. A single unit works fine, but 2 or more lose sync randomly. Separately, I can't get Sonar to see the hardware as 24 bit, but this is a minor consideration at this time as I primarily use Cubase 4.1. I have not yet tried with Ableton Live 6.0.5.
Responses: No responses posted.
