Drum editor
Posted: Thu Oct 18, 2007 9:38 am
by jsd540
whenever I take a beat from a record I have I use recycle create a rex and load it to battery, then all I have to do is drop eighth notes in the drum sequencer and for the most part it all sounds like the original file.
I have a loop loaded right now that needs to be tweeked up to 128 ths so I can nudge 2 or 3 of the notes just a hair and that should do it , hoever I haven't been able o get the drum matrix up that high. What am I doing wrong ???
I know If I work with the audio file and groove quantize I can get closer but then I cant trigger it the way I feel most comfortable.
Is there a way to nudge the notes in drum sequence to a 128th ?
Re: Drum editor
Posted: Thu Oct 18, 2007 10:36 am
by rentadrummer
As far as I know, the smallest increment you can work with in the Drum Editor is a 64th note. That being said, can you hear the difference when shifting a note by 1/128th, or is it necessary to do so for another reason? I'm not sure I understood what you were doing.
I'm not in front of my music computer right now, but there might be a setting in the Quantize Region command that allows you to specify an increment smaller than 1/64th. This, by the way, is a handy tool for snapping a note to the grid. You can select mulitple notes and have them all shift by the same degree.
Posted: Thu Oct 18, 2007 12:42 pm
by jsd540
I just need to shift 1 or 2 of the slices a bit and 32nd is still too coarse, just a bit of tweeking 64ths might do it, but iit is noticeable on those 2 or 3 slices... Groove quantize mmmm ?
Posted: Thu Oct 18, 2007 2:18 pm
by rentadrummer
Sorry. I should have said the smallest increment in the Drum Editor is 1/64th (I hope) and I've edited my original reply.
Posted: Fri Oct 19, 2007 10:38 am
by jsd540
yep 64ths
still not there... will the sequence editor permit 128, or allow me to nudge in very small increments. those 3 notes are killing me
Re: Thanks
Posted: Fri Oct 19, 2007 11:45 am
by rentadrummer
jsd540 wrote:yep 64ths
When you click on the note, look at the event information, particularly the time, at the top of Drum Editor window. Can you move the note one 64th, and then edit the time by a few ticks manually? Or, just edit the time manually in the first place.
Posted: Fri Oct 19, 2007 12:17 pm
by chadd
What if you use the scale time function to double the length of your loop, then nudge the notes by a 64th, then scale time back to the original length? Wouldn't the end result of the edit be a 128th?
mmmmm
Posted: Fri Oct 19, 2007 10:18 pm
by jsd540
That sounds like a work around... will try it tomorrow...
