Dedicated internal drive suggestions for G5?
I want to get a dedicated audio internal drive for my dual 2.5 G5. What should i get? any suggestions?
DP 4.6 Dual 2.5 G5 OSX.39 2.5GB RAM 2408mk3 with pci 424 and 1224. MTP AV Autotune 4, waves platinum 5.x NI B4, Mach 5, arturia minimoogV. API, calrec, UA2610, Distressors, adl1000....yaddayadda
Re: Dedicated internal drive suggestions for G5?
If it's speed you want -- I installed a 10K rpm ATA 70GB Raptor and it's been running great -- but I really don't know if it makes that much a difference -- although you figure it should be 25% faster than a 7200 rpm drive. I'm more concerned about upload speeds from my sampler libraries, so I put a lot of stuff on the Raptor.
2.5Ghz G5, DP 4.61, OSX 10.4.5, 2408MK3/PCI-424, MTP/AV, UAD-1, Spectrasonics, Mach5, GPO, Albino, Panasonic DA7
hey thanks! What is the raptor? who makes it? Do you know if they make a bigger drive?
barefeats.com is a great source for this stuff... this is good reading:
http://www.barefeats.com/hard39.html
15" Macbook Pro Retina quad 2.5Ghz 16G/512G SSD (2015 model),
Raven MTi2, 4k Vizio TV, Pegasus TB2 RAID5 (6TB),
UAD TB Apollo Twin Duo, UAD TB Satellite Octo, Tascam DM-3200/IFFW-DMII
DP 9.0.2 (Pro Tools 12.4, Logic Pro X 10.2.2), OS X 10.10.5
- qo
Western Digital makes it. And, no, 74GB is the largest one I believe. I bought one a couple weeks ago, but had to remove it for now since space is higher priority for me than speed at the moment. My plan is to buy an external SATA enclosure and install it there. Our local Fry's doesn't have these enclosures in stock though, so I'm gonna have to mail order it.Originally posted by DPapolooza:
Just to be clear, by "SATA enclosure" I mean an enclosure that holds a SATA drive and connects to the Mac via SATA (as opposed to an enclosure that holds a SATA drive and connects to the Mac via Firewire or USB 2.0).
- BKK-OZ
several other threads on the same subject, use the search, here are a couple for you:
Ram/Hard drive reccomendations
SATA Drive ideas
Second Drive for audio?
Advice on SATA drive needed....
Look and ye shall find.
SATA Drive ideas
Cheers,
BK
- M Kaku
BK
- M Kaku
- BKK-OZ
...and just saw this over @ creativemac.com
its a 2.5 Terabyte SATA II external enclosure from LaCie. Whoa.
Cheers,
BK
- M Kaku
BK
- M Kaku
- qo
OMG! In the spirit of Wayne's World ---> It will be mine.Originally posted by BKK-OZ:
- BKK-OZ
don't do it Qo, you'll just end up downloading bit torrent stuff 24/7 just to see if you can fill it!
Cheers,
BK
- M Kaku
BK
- M Kaku
- qo
Don't tell the RIAA. No, seriously, what's bit torrentOriginally posted by BKK-OZ:
