So today when I attempted to load up a virtual synth, I noticed that most of them are grayed out and I cannot select them! I have no idea why, I havent relocated files or installed/uninstalled anything. The components are all still there where they should be. The list just shows a majority of my VI's (au, mas, and vst) grayed out. Any thoughts or suggestions?
Thanks alot, i know i've seen posts on similar topics in the past, but im having trouble finding the same sort of problem on the forum. Thanks for your help
i cant even choose them to get to that step. im talking about when i go under the project menu and select instrument tracks. also i just noticed an extra problem. any time i try to load a session that has a grayed out vi in it, DP quits!
any help is most appreciated. thanks alot
Your bundles may be corrupted. Try reconfiguring your audio bundles.
Actually, come to think of it, I have seen a similar problem before in which the presets on the VI's were corrupted. I reconfigured the presets in the VI's, and they all worked again, and DP stopped crashing.
|l|OS X 10.12.6 |l| DP 10.0|l|2.4 GHz 12-Core MacPro Mid-2012|l|40GB RAM|l|Mach5.3|l|Waves 9.x|l|Altiverb|l|Ivory 2 New York Steinway |l|Wallander WIVI 2.30 Winds, Brass, Saxes|l|Garritan Aria|l|VSL 5.3.1 and VSL Pro 2.3.1 |l|Yamaha WX-5 MIDI Wind Controller|l|Roland FC-300|l|
Thanks! the bundles thing helped. I did mess with them before this all happened. I do have a song that is still crashing, but i think that i just need to add a bundle that i took away. thanks again!
