recommendations- pc laptop and motu
SonarScope
Post by SonarScope »
Hi to all
i like to ask You for recommendations for laptop with XP pre install
and motu interface
i like to get 24 audio playback from Cubase or Ableton to 01v96 for live performance
thanx
best regards from Croatia
emil
SonarScope
? bump
really slow response
from what is on a Motu site i guess is not possible to get from USB or fire wire Motu interface 24 separate outputs
is that correct ?
probably MOTU 828mkII = 8 analog + 2 main stereo + adat 8?
so 10 analog + 8 digital = 18 -- so i need adat to analog converter
apparently Motu is not providing single adat to 8 analog outuput interface what i can connect to MOTU 828mkII - maybe i am wrong ?
please help
thanx
regards
emil
Pappy725
Post by Pappy725 »
There is also S/PDIF in that gives you two more channels. I added the 8Pre to my rig and I've got 18 solid analog ins from the 828 and the 8Pre. I don't think you can get 24 seperate outs even with the two units.
HTH,
Stephen
MacBook Pro (Retina, 15-inch, Early 2013)
2.4 GHz Intel Core i7, 8GB RAM, OS High Sierra 10.13.2, DP8.07, 256GB SSD
828mkII, 8Pre, Alesis M1 Active Mk2, Ext. FW drives, Yamaha fretless bass, Kay upright bass, Wechter acoustic/electric, trombone, baritone and a proclivity for polka music. (With sufficient quantities of beer) and I play country music.
splatterbass
Post by splatterbass »
or daisy chain adats.
works no problem.
SonarScope
splatterbass wrote:or daisy chain adats.
works no problem.
hi
please can You explain how to get more adats output
what Motu units i should get
thanx
emil
SonarScope
copy paste from
http://www.motu.com/products/motuaudio/ ... tures.html
Expandable - add additional UltraLite, 828, 828mkII, 896, 896HD or Traveler FireWire interfaces for additional I/O.
is posible to connect more UltraLight together to laptop and have all inputs and outputs visible in Cubase ( Asio )?
thanx
regards
emil
splatterbass
i have an 828 mkII.
i hook up an adat from optical out 828mkII to optical in on adat 1.
optical out from adat 1 to optical in on adat 2.
optical out on adat 2 to optical in on the 828mkII.
set motu audio console optical options for adat, ready to rock.
