motu pci 2408 mkIII problem
Posted: Tue Aug 07, 2007 11:53 am
by meteo
hi, i have a macpro and i bought the 2408mkIII. when i connect and i try to open the system audio setup, it tells me that an error has occurred. i re-installed the driver but nothing changes. digital performer only shows me the analog connections. do you have any advice?
Posted: Tue Aug 07, 2007 3:23 pm
by meteo
Posted: Wed Aug 08, 2007 1:23 am
by Frodo
meteo:
What version of the driver did you install? MOTU driver 1.1.2 requires OSX 10.4. If you don't have either of these, uninstall the driver.
Make sure the PCIe-424 card is properly seated.
Before re-installing the driver, restart the computer and set your computer's audio to Built-In (System Preferences> Sound). Try to open your Audio-MIDI utility again to make sure it doesn't give you an error code before you move ahead.
If it works, then install MOTU PCI-424 driver 1.1.2 and try again by setting your Audio-MIDI inputs and outputs to the PCI-424.
Repair Permissions using Disk Utility (Applications> Utilities).
Buona fortuna!
Posted: Wed Aug 08, 2007 4:48 am
by meteo
hi frodo, thanks for helping. i use mac os x 10.4.10
and i've installed the latest drivers that motu has released. i downloade them directly from motu site. i've also done what you said but nothing has changed.
any time that i try to open the system setup it gives me that error and in digital performer i only see the analog channels.
do you have any other idea?
Posted: Thu Aug 09, 2007 12:10 am
by meteo
no one can help me? :(
Posted: Thu Aug 09, 2007 6:50 am
by emulatorloo
meteo wrote:no one can help me? :(
Time maybe to ask MOTU:
http://www.motu.com/techsupport
GOOD LUCK!!!!
Posted: Thu Aug 09, 2007 10:40 am
by meteo
it was the first thing that i've done. but it seems to speak with a wall.
no response.
