Reset Faders and Pan Knobs
Posted: Thu Aug 02, 2007 12:04 pm
by Trachnyne
Is there a quick way to reset all of the volume faders to zero and pan knobs to center in the mixing board? And for that matter, the sends as well?
Posted: Thu Aug 02, 2007 12:26 pm
by magicd
Double click on a fader or send to reset to 0.
Double click on a panner to reset to center.
To reset multiple tracks simultaneously, display those tracks in the mixer. Hold Down the W key and Pull a fader down to zero. All faders will go to zero. Release the mouse button and W key. Hold the W key down again and double click on the fader. All faders jump to zero.
The W key temporarily groups the volume fader or pan knob. It does not affect the sends. You'll have to reset the sends individually.
Magic Dave
Posted: Thu Aug 02, 2007 12:54 pm
by Appalachian Boy
magicd wrote:Double click on a fader or send to reset to 0.
Magic Dave
wow i learn something from every thread. thats why i love this forum
Posted: Thu Aug 02, 2007 2:26 pm
by Trachnyne
Magic Dave
You're a life saver! Thank you!!!
Posted: Thu Aug 02, 2007 3:44 pm
by Tim
If there many many tracks, rather than adjusting each send individually, it may be faster to make a snapshot of all send levels, then use Region/Change Continuous Data to adjust it on all selected tracks at once. Hit play to make levels change, then erase send automation (or disable send automation then Undu to before the Snapshot was made) if desired. I'll usually go to Setup/Automation Setup and Option click (to enable only) Sends before doing this operation (set it back to normal afterward).
I think that the Audio Assignments window should have Send Assignments in it too.
Re: Reset Faders and Pan Knobs
Posted: Tue Apr 13, 2010 5:14 pm
by lodstudios
The reason I love this forum! It always pays to search before you ask, it saves so much time! Thanks for the tip, now back to mixing!!!
Keith
