Auto Tune 4
cubehead
Auto Tune 4
Post by cubehead »
I am having problems with Auto Tune 4 in DP 5. It takes quite some time to process and the graphics get really big in the autotune display. Any thoughts?
Chris Cubeta
http://www.galuminumfoil.com" onclick="window.open(this.href);return false;
Dual Core Intel 3GHZ. DP 7.24. 24 Channels of Lynx Aurora, Neotek Elan, Api, Daking, Five Fish, Purple Audio, UA 1176 and a bunch of other crap.
azusa749a
Post by azusa749a »
Don't use MAS. Take it out of MAS folder and use the AU instead.
cubehead
Post by cubehead »
Thanks but I tried that already. Still doesn't work
Chris Cubeta
azusa749a
Post by azusa749a »
I have Autotune 4.2.5, and the AU plug in works on mine and a lot of people.
Other than that, upgrade to a version 5.
Well, in the meantime, you can use DP's pitch correction.
I use the AU version of AT4, and it works fine. PPC, as you can see.
HC Markus
https://rbohemia.com
jlaudon
Post by jlaudon »
I remember having problems with AT4 with DP 5 - are you using DP5.11?
Anyway, I upgraded to AT 5, and also recently downloaded the AT5 update - made a huge diffference in opening the plugin, etc (faster, more responsive).
MacBook Pro 2021 (M1 Ultra) with 64 gigs RAM. DP 11.23
bongo_x
Post by bongo_x »
I think the AT5 upgrade is pretty great all around. it seems to me like it actually works better, as in smoother, less glitchy. I only use the graphic mode, but the pitch centering (something like that) is great as is the following the host clock. huge improvement.
bb
tommymandel
Post by tommymandel »
I haven't upgraded to v.5 yet, i use v.4, and it works well with my G5 DP 2.3, Tiger and DP 5.11 (haven't tried it since i upgraded DP to 5.12.)
DP 11.32 12core(5,1): 64GB/10.14.6, two 24i/o's, two 2408mk3's, 4pre, MicroLite-- MBP 2015 16GB/ 2TB 'Blade SSD 10.14.4, Mainstage, Numa C2x, ReMOTE SL -- 32 Lives, Pro-53, SampleTron,Keyscape,MTronPro,RolCloud,Icarus,Dune,OB-E; Clearmountain Domain,Soundtoys,AdrenaLinnSync, LinnSequencers,Tempest, Montage, JU80, Sledge, Prophet-X, T8, OB-6 V-Synth, s70xs, D-50, TS-10, JD800, Karma, Pa-1x B3, Wurly, Mason Hamlin.
