Eject button not working...
In the past couple of months the eject button on the keybaord has stopped working on both my Macs (MacPro, G4 Dual). The only way I can open the drive is with the eject button in itunes. Any ideas
Lenovo Yoga i7, 16RAM, DP 10.11, Waves analog modeled plug-ins, AmpliTube, Shreddage 3 Jupiter, Mackie HR824 Mk1, Tobii Eye gaze mini.
Yes, I do everything using only my eyes. #ALSsucks
Even when I'm new school I'm old school.
Re: Eject button not working...
arsis wrote:In the past couple of months the eject button on the keybaord has stopped working on both my Macs (MacPro, G4 Dual). The only way I can open the drive is with the eject button in itunes. Any ideas
Did you upgrade to OSX 10.4.9? If so, then there is a delay built into the system...just hold the button down for a couple of more moments until it ejects.
There have been some very strange things like this that happen, and I've yet to install 10.4.9.
I've found that to eject a CD from iTunes, clicking the eject icon next to the CD is really the only way I can get it to work.
Sometimes the eject button will only work if the CD is highlighted on the desktop. Other times it just ejects the CD as normal. I've not found any real behavioral patterns with it.
And, there is still this strange thing in the GO menu-- I've never gotten that to work in any version of OSX-- click it and nothing happens.
I actually like the new behaviour, especially on the Macbook - many a time I dive for the backspace key and knock the eject button. Now ejecting feels like a deliberate action. I assume this is intentional, not a quirk.
kind regards
Stephen
kind regards
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Perhaps someone else can find it for me, but I know there is a file preinstalled somewhere on your Mac that you can run and it will install an Eject button up in the menu bar. I had to find this for a friend of mine a while back who came from the PC world and was using a non-Mac keyboard and couldn't eject CDs/DVDs. I just don't remember where to find this and I'm too damned lazy to look.
THis one should do it. I was looking for a different app tht added icons with various functions to the menu bar, but I cannot remember what it was.
http://www.versiontracker.com/dyn/moreinfo/macosx/20089
wow, thanx, just what I needed
DAW: PowerMac G5 2,0GHz Dual Core, 3GB ram & 2x250GB storage, OS X 10.4.9 running Digital Performer 5.12.
OUTBOARD: Ibanez RG 7620 with EMG 707 & EMG 81/7, Peavey Triple XXX, Ibanez TS-9, T.C. Electronics G-Major, ADA Stereo Tapped Delay, Rocktron Intellifex LTD, Samson S-Direct Plus.
TinkerTool will let you add an Eject button for the optical drive to your menu bar.
TinkerTool: Description
15" MBP - 2.4 GHz, OS 10.4.11 :: DP 5.13, Reason 4, Live 6.0.7 :: MOTU 896 :: Korg MicroKontrol, Casio CDP-100
- mhschmieder
This problem comes up now and then, but I think only since I tossed my Apple keyboard for one from Macally a few months ago.
The problem always goes away, but not always after a reboot. Usually after repairing permissions.
Each case may be different, but my theory on my own particular occasional problem with the eject button is that it seems to happen after doing a USB driver installation for a new hardware synth or controller.
Note that the F12 key can serve as an eject button as well, in most cases. I have never had the F12 key fail, but have trouble remembering it, so prefer the dedicated eject key.
There are indeed times when there is a bit of a delay (up to a minute even). I believe this happens in cases where the system is reconstituting itself after perhaps a software installation that may have triggered a performance enhancement run (which sometimes involves a behind-the-scenes defrag of the system drive, but not always).
- auptown
Also, you can modify the toolbar on the Finder windows with the Customize Toolbar command. I set mine up with Eject, Delete, Burn Disk, New Folder. [/img]
MacPro 2x2.66, 5G ram, 1 SATA, 2 raptors, 2408 mk3, MOTU HD192, Mackie MCU
Dual 2.0g G5, 7g ram, 1 SATA drive, 1 IDE drive, Duende, Liquid Mix, UAD-1,
OS X 10.4.11, DP 5.13, MOTU 2408mk3, BFD, RMX, Atmosphere, EWQLSO Gold XP, Ethno, Grace m906, Blue Sky 5.1 monitors
MacBook Pro 2.13 3G ram, ext FW drive
Go here:James Steele wrote:Perhaps someone else can find it for me, but I know there is a file preinstalled somewhere on your Mac that you can run and it will install an Eject button up in the menu bar. I had to find this for a friend of mine a while back who came from the PC world and was using a non-Mac keyboard and couldn't eject CDs/DVDs. I just don't remember where to find this and I'm too damned lazy to look.
<Boot HD>/System/Library/CoreServices/Menu Extras
Double-click the file "Eject.menu" and the new menu will appear. To remove it, Command-drag it down onto the Desktop.
Kind regards.
Dave Bourke
– ideation –
Mac Pro Quad Xeon 2.66 GHz, 5 Gb, OS X 10.5.8, iMac 24" 2.4 GHz Intel Core Duo, OS X 10.6.2, Mac G4 dual 800 MHz Quicksilver, DP 7.11, PCIe-424/24i, UAD-2 Quad/UAD-1e, PowerCore Firewire.
– ideation –
