Anyone using Duende with PowerMac G5 and liking it?
Posted: Mon Mar 19, 2007 10:20 am
Wondering what you think of Duende?
Thanks for the information.
Peace..
Curtis
Peace..
Curtis
https://www.motunation.com/forum/
Ah, I'm not sure about audio interfaces sharing the FW with Duende, at least at this time.curtisb wrote:Thanks for your input. That is the same system I am running, but I do have a Motu 828mk11 hooked to my FW.
This gave me a choice of getting either a FW host card or an eSATA host card. Since my hard drive situation needed help, I chose the eSATA route and added a 1.25TB RAID plus a pair of Raptor 10k drives. FW port was wide open for Duende.SSL wrote:If Duende and Mackie are used on the same firewire bus (i.e. if a PCI firewire adapter is not used) then certain conditions apply for their mutual correct operation.
We have found through testing that the pair behave well when the whole system is booted from cold in the following order;
1: power up Duende
2: power up Mackie Onyx [ie: any firewire audio interface]
3: power up Mac
If the Onyx is power cycled whilst the system is running then Duende will probably not be recognised on the firewire bus until a system reboot.
If Duende is power cycled whilst the system is on then the Onyx may well malfunction until a system reboot.
Our tests have been unsuccessful at 88.2/96kHz. If you wish to work at high sample rates with these two units we advise the purchase of a PCI firewire adapter to create a separate firewire bus.
