AU plugins don't display in 5.11
Posted: Sun Mar 11, 2007 6:34 am
by mulletsaison
When I select any of my AU plugins or instruments, the header of the plugin/instrument window shows up, but the actual plugin/instrument window does not. The preset menu is populated correctly, it's just the graphics just don't show.
Any advice?
Thanks in advance.
Posted: Sun Mar 11, 2007 6:38 am
by Yiannis
Try to trash the preferences and let Dp scan the AU again
Posted: Sun Mar 11, 2007 8:02 am
by mulletsaison
Yiannis wrote:Try to trash the preferences and let Dp scan the AU again
Didn't change the behavior unfortunately, thanks for the help, though. Now at least I know where those preferences are.
Posted: Sun Mar 11, 2007 9:39 am
by David Polich
I know it sounds silly, but are you sure your audio interface is switched on and your Mac recognizes it in Core Audio?
Re: AU plugins don't display in 5.11
Posted: Sun Mar 11, 2007 9:43 am
by emulatorloo
mulletsaison wrote:When I select any of my AU plugins or instruments, the header of the plugin/instrument window shows up, but the actual plugin/instrument window does not. The preset menu is populated correctly, it's just the graphics just don't show.
Any advice?
Thanks in advance.
We just went thru this one not too long ago. I will see if I can find the thread.
At anyrate, you need to set the output assignment of your VI to the sound card/audio interface you are using (that is what sound card/audio interface it is going to play thru). Once it knows that, then it will load.
See where I have assigned my audio to my Delta RBUS 1-2? You need to do the same for your VI. Then it will open and show you the graphics.
Best of luck
Here is that recent thread:
http://www.motunation.com/forum/viewtopic.php?t=18377
Look down at magicdave's post. beginning with "Check the Output Assignment for the Instrument Track in the Tracks Window."
Posted: Sun Mar 11, 2007 3:09 pm
by Noam
also make sure that mono plugs and inst.s are assigned to mono outputs / stereo to stereo outputs -
