DP and Liquid Mix
DP and Liquid Mix
Who is using Focusrite Liquid Mix and DP?
How's it going?
How's it going?
waxman
I've been using it since it was first released, and use it on every production I mix.
I only use an average of 3 LM plugins, compression mostly, and have never maxed it out, but between LM and my 2 UAD-1 cards my dual 1.8 G5 will be in service at least until next September
I also have the Waves SSL bundle and compared those emulations to the LM. The LM SSL EQ emulation sounded better to me, but not by much.
The Waves Buss Comp. emulation was a bit more punchy with identical settings, but not by much. Dollar for dollar the LM is the better deal IMHO.
Great family and friends!
F. Douglas
F. Douglas
DP & Liquid Mix
We use Liquid Mix and dp5.11 on MacPro. Although I am satisfied with the sound I have latency troubles now and then. I can not say what they depend on, but especially on mixes of live-orchestra recordings I am very carefully using it because of unwanted flanging effects.
We also use LM in some Projects of Final Cut Pro too.
Comparing price/value I must say it is absoluteley worth the money.
MacPro 3,3GHz 6-core, 16GB, OSX 10.7.5, dp8, mach five 3, msi, motu 2408mk3, 2x 1224, 308, melodyne editor, stylus rmx, omnisphere, trilian etc.
I have been using it since September on my G5 with great results. I did need to add a FW card to get enough bandwidth to use my Traveler and FW drives at the same time.
Love the sounds, there are so many options. I used about 24 instances on a surround mix that I did, no problems. Highlights so far: SSL, Distressor, Fairchild, dbx, LA-2A ( emulations of course!!)
Have just tested it with my new MacBook Pro, and all is well, although have yet to test it with the Traveler and a drive to check whether the system can cope.
Highly recommended, especially at the price.
kind regards
Stephen
BTW never had any latency problems, I found you must always check the 'Always run in real time' option for the plugin, as the default is off.
kind regards
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Thanks for the input. I wanted to see if anyone was successful with multiple FW devices while LM was running... I love the LM also but the FW bandwidth overload is a drag...
I cannot use more then one device with it and LM is all by itself on a external PCIe FW card. Also it will not run if you have 2 cards in. Focusrite said there will be a new software release this week that should solve that problem. Other then the FW issue LM is the best plug I have heard. I A/B with my waves platinum and it is so much better. The overtones are there and the sound is amazing...
waxman
Someone posted elsewhere that OS 10.4.9 is about to be released and it also addresses some FW bugs, too.waxman wrote:...I cannot use more then one device with it and LM is all by itself on a external PCIe FW card. Also it will not run if you have 2 cards in. Focusrite said there will be a new software release this week that should solve that problem. Other then the FW issue LM is the best plug I have heard. I A/B with my waves platinum and it is so much better. The overtones are there and the sound is amazing...
So odd about the the device being a bus hog-- Duende is the same way-- won't run if any other FW devices are connected. Hmm.
it is up to the programmers...
waxman
Someone, indeed!The Humble Hobbit wrote:... Someone posted elsewhere that OS 10.4.9 is about to be released and it also addresses some FW bugs, too.
http://www.motunation.com/forum/viewtopic.php?t=18051
Not so odd in this day and age, really...The confused, but about-to-be-enlightened hobbit wrote:So odd about the the device being a bus hog-- Duende is the same way-- won't run if any other FW devices are connected. Hmm.
"It's all about me" is no longer a disease; it's a plague.
Liquid mix at a distance???
Is anyone using a Liquid Mix with their production macs machine room a fair amount of feet away? (30ft in our case) Perhaps with a FW repeater?
Regards,
DLevy
mgr, Legacy Lab
Regards,
DLevy
mgr, Legacy Lab
MacPro to LiquidMix distance
@labman
we use the liquidmix in a distance of about 12 meters to the macpro; we use a fw repeater and everything is okay so far...
regards,
lu
regards,
lu
That silly ape was only half-correct, so for the sake of accuracy:monkey man wrote:Someone, indeed!The Humble Hobbit wrote:... Someone posted elsewhere that OS 10.4.9 is about to be released and it also addresses some FW bugs, too.
The Speculative hobbit wrote:... 10.4.9 appears to be on the way, but it's not 100% clear what this update will do.
There. Would you believe I realised this whilst chopping celery today.Then wolfetho wrote:... I've heard that a new audio firewire driver is also included in the 10.4.9 update.
Go figure; the monkey has an acute case of UnicorNitis, no doubt.
