techsupport@motu.com
Subject: Re: Ultralight Driver Installation Problem
Date: Thu, 1 Feb 2007 10:32:11 -0500
To:
Hi Ron,
Thanks a lot for the email.
We have indeed noticed that at some points you must go into Windows device manager and go through the Found New Hardware Wizard to finish up the driver installation. In some cases it may seem that Windows does not fully recognize the drivers automatically.
But in any case, glad to hear that the UltraLite is working smoothly for you now. Please let me know if you have any further questions on this unit in the future.
Regards,
Barrett
MOTU Tech
In your reply, PLEASE include previous email correspondence for reference
and PREFIX YOUR SUBJECT with "ATTN: Barrett."
Please include your system specifications.
MOTU Technical Support:
voice : (617) 576-3066 [Mon-Fri 9am-6pm Eastern]
fax : (617) 354-3068
email :
web :
http://www.motu.com/techsupport
downloads :
http://www.motu.com/download
registration :
http://www.motu.com/techsupport/register
On Feb 1, 2007, at 8:47 AM, Ron van Wolferen wrote:
Hi,
I recently bought a MOTU Ultra Light. (UL00011407)
While trying to install the drivers I encountered a problem.
I followed the manuals instructions exactly.
- (ultralight turned off, not connected to computer ~DELL Latitude D520 Laptop; fully updated (jan 2007) WinXP pro NL~)
- ran setup.exe from XP drivers folder(32bit drivers)
- installed the drivers (choosing continue installation (for all 5 seperate drivers) on "not digitally signed by Microsoft" dialog)
- turned of computer
- connected the (turned on) ultralight
- started up the computer
- The MOTU software was installed
- on starting the audio setup software I get a dialog No MOTU device connected
no succes... (drivers were not recognised)
after repeating the manuals instructions three times (uninstalling - installing) I finally decided to use the windows installation wizard (against the manuals advice)
with succes. (The UltraLight works the a charm)
I'm guessing the latest winXP updates do contain driver support for the MOTU ultralight, and might even cause the original driver setup.exe to fail...
I thought, if not known allready, you might like to know about this issue and its solution and perhaps investigate?
If more specification is needed please let me know..
Hope to have contributed somewhat, thanks for developing the Ultra Lilght!
Kind Regards,
Ron van Wolferen.
