Hi
I have a Studio Project C1 Microphone that is making a low level scratching noise. After troubleshooting a bit I think that it is coming from the mic's diaphragm. I was told that moisture can do that to mic's diaphragm. Any ideas on how to fix it?
Bad Studio Project C1
- Dwetmaster
- mikebeckmotu
That's sad! I don't have an answer for you, but I'm wondering - do you usually use a pop shield? Do you usually keep the mic in its case? I've been doing both in order to forestall the same issue. I just don't know if I'm paranoid by doing this. I've only used my C1 about ten times so far, though.
8-core i9 MacBookPro 16-inch, 16gb ram, Catalina, Focusrite Scarlett 18i8, DP not installed yet
The ambient conditions where a mic is kept and used have a real impact. If a room is cold and the mic has been on for only a short time, close-up vocals can cause condensation to form on the diaphragm, which can cause noise, loss of frequencies etc.
Always a good idea to let a mic warm up before use, and try to avoid storing at low temperatures. And yes, a pop shield is helpful if you are using the mic for close vocals. Also, some singers expel more moisture than others!!!
Hope you get the problem sorted
kind regards
Stephen
kind regards
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
