configure hardware settings every time I change locations?
I use a motu 828 with my macbook pro at home but when I take my macbook out and want to work form headphones I have to change all my outputs to built in output. its a real pain. is there anyway to automatically switch all the outputs at once?
thanks
Derek
thanks
Derek
- emulatorloo
maybe it is the post thanksgiving glow, but I would be happy just to have a Macbook Pro!
Dunno, one option might be to set up two user accounts!
Home -- 828
Away -- internal audio.
I am about 98.9% sure that would work. I have two accounts on my home machine, each set up to use a different audio interface. I never run DP on one of the accts though so I can't guarentee that you will have the desired results there. But I pretty sure it would work.
Maybe somebody will come up w a better solution.
in the meantime, I am thankful you have a Macbook Pro!
Home -- 828
- Mr_Clifford
Re: configure hardware settings every time I change location
I always run all my audio tracks to an Aux bus called 'MIX'. If i need to route the audio to a different output I just have to change the output of the one Aux track rather than every single audio track.aquaman wrote:I use a motu 828 with my macbook pro at home but when I take my macbook out and want to work form headphones I have to change all my outputs to built in output. its a real pain. is there anyway to automatically switch all the outputs at once?
thanks
Derek
Of course, changing the output of every audio track is pretty easy by selecting all of them and hitting opt-A to bring up the audio assignments box.
DP 9.52 Mac Pro 10.14.6 RME fireface800. Sibelius. Dorico 4
- auptown
Of course there is also the Bundles window, you can change the desitination for any named output or input. In fact, you can save and recall bundle setups which makes it really easy.
MacPro 2x2.66, 5G ram, 1 SATA, 2 raptors, 2408 mk3, MOTU HD192, Mackie MCU
Dual 2.0g G5, 7g ram, 1 SATA drive, 1 IDE drive, Duende, Liquid Mix, UAD-1,
OS X 10.4.11, DP 5.13, MOTU 2408mk3, BFD, RMX, Atmosphere, EWQLSO Gold XP, Ethno, Grace m906, Blue Sky 5.1 monitors
MacBook Pro 2.13 3G ram, ext FW drive
- Dwetmaster
I definitely second the use of audio bundle. You just change your main out to what ever you want. You don't have assign everything to a special bus.
