Newbie question on the 828 MKII
boechler
Post by boechler »
Hi,
I just purchased an 828 MKII on eBay. It has not been shipped yet. The seller does not think he has the manual or other software that came with the unit. Looking on the MOTU website it appears one can purchase a manual, but there is no manual download available. Is this correct? Also, does the CueMix software normally come on a disc with the unit? Can it be downloaded if the disc is lost? Thank you for your help. Brian.
jarok
Post by jarok »
Hi
Look at here:
http://www.motu.com/products/motuaudio/ ... tures.html
Quote:
Includes AudioDesk full-featured sample-accurate workstation software for the Macintosh with recording, editing, mixing, real-time 32-bit effects processing & sample-accurate sync.
CueMix is coming normally with the AudioDesk CD.
jarok
boechler
Re: CueMix software
Post by boechler »
Thanks jarok. Does anyone know if the CueMix software is downloadable. I have contacted Tech support but I would like to find out before I pay for the item.
Jidis
Post by Jidis »
Brian,
On the 424 stuff at least, CueMix will just install as part of the driver bundle.
Hope that helps.
boechler
Post by boechler »
Thanks a lot Jidis.
Atardecer
Post by Atardecer »
Jidis wrote:Brian,
Hope that helps.
Same too with the 828 MKII. Cuemix comes with the drivers.
Regards
Airstorm
Post by Airstorm »
It's probably wrth noting also that Cuemix is not used/required if using within your sequencer/multitrack program... In Windows anyway. Did someone say Ebay? Gotta run, cya.
