LATENCY Summing OTB back to DP
John Scalia
Post by John Scalia »
What is up with this:
I sum a drum group out to my analog console(for some stereo compression) then feed it back to DP. It always sounds messed up and phasey. I try to nudge it this way and that but it never gets right with the original drum mix. I did a search in the Forums for a similar problem to no avail. Would anyone care to jump on this one?
John Scalia
dp4.6/ MacG4/ HD192
builder
Post by builder »
try nudging it exactly by your buffer size. You can set the nudge by lets say 512 samples, then select the tracks and the back arrow once
Music - http://www.missingpalmerwest.com/Missin ... songs.html
Dual 2.0 G5 (Rev. A), 4.5 GB Ram, Powerbook 1.5 GHZ 1.5 GB Ram, (BLA) 828mkII, UAD-1 X2 , 10.4.8, DP 5.13, Sebatron VMP2000e, Sytek MPA, Many Mics
96khz
Post by 96khz »
Hi. The last time this subject was commented here was a few weeks ago in a post entitled "I have a dream of external delay compensation".
Link:
http://www.unicornation.com/phpBB2/view ... hp?t=15212
auptown
Post by auptown »
Yes, and I wrote a plug-in that computes the exact delay or latency between any two audio signals in DP. You can use it to measure exactly how much to nudge a track, or to set the delay in a plug-in that let's you compensate for latency. My plug-in (free) uses the Pluggo runtime environment (free).
If anyone wants this let me know and I will be happy to post it.
MacPro 2x2.66, 5G ram, 1 SATA, 2 raptors, 2408 mk3, MOTU HD192, Mackie MCU
Dual 2.0g G5, 7g ram, 1 SATA drive, 1 IDE drive, Duende, Liquid Mix, UAD-1,
OS X 10.4.11, DP 5.13, MOTU 2408mk3, BFD, RMX, Atmosphere, EWQLSO Gold XP, Ethno, Grace m906, Blue Sky 5.1 monitors
MacBook Pro 2.13 3G ram, ext FW drive
TheHopiWay
Post by TheHopiWay »
auptown wrote:Yes, and I wrote a plug-in that computes the exact delay or latency between any two audio signals in DP. You can use it to measure exactly how much to nudge a track, or to set the delay in a plug-in that let's you compensate for latency. My plug-in (free) uses the Pluggo runtime environment (free).
Just sent you an email regarding this....
Thanks in advance!
sdfalk
Post by sdfalk »
Yes please..
I've emailed you
Stephen
Vato
DP speaks of auto latency compensation
Post by Vato »
96khz wrote:Hi. The last time this subject was commented here was a few weeks ago in a post entitled "I have a dream of external delay compensation".
Link:
Thanks for this info. I foolishly thought that DP's new automatic latency compensation was a cure for this. Dont get me wrong -I love Dp- I just wish these sort of things (like outboard summing) would be a realtime thing.
Please tell me this: Did did anyone notice a change in this sort of problem when they moved from a G4 to a G5. Or maybe in the upgrade toDP5? I would like to fantasize that we are a Mac upgrade away from DP running more like pro tools(TDM) :roll:
Vato
Native= We dont have the$ to buy the real thing?????
Post by Vato »
Forgive my title. Im not trying to start a war. I just heard a guy say something like that the other day. I think as far as budgets go, I would have to agree somewhat. However, as I stated in the latter reply, I just find it very interesting that protools sort of stands on its own "top of the world". I think its very exciting to watch the rest of the audio world catch up and throw some competetion at those bastards.
Re: Native= We dont have the$ to buy the real thing?????
Vato wrote:...I think its very exciting to watch the rest of the audio world catch up and throw some competetion at those bastards.
Amen, brother. :lol:
M
Resonant Alien
Post by Resonant Alien »
If you have UAD, you can use the included delay comp plug for external hardware. Works great.
builder
Post by builder »
Resonant Alien wrote:If you have UAD, you can use the included delay comp plug for external hardware. Works great.
Could you give me an example please... I just can't pitcure it for some reason.....
Resonant Alien
The UAD delay comp is the plug you had to use on your UAD plugs before DP had auto delay comp. You inserted it on all the tracks that did NOT have UA plugs going. It delayed the signal of the unprocessed tracks so that they would then play back in time with the delayed tracks running through UAD. Since ADC came to DP, you don't need that plug for UAD anymore, but it still works on hardware...
i.e. you insert the UA delay comp plug on all tracks that are NOT going through the hardware - the UA plug delays all those tracks so that they will play in time with the delayed track going out through the hardware. You play with the "plugin count" parameter in the delay comp to get the right delay, but I've found that setting it for 2 plugs seems to work well.
To make things easier, you can buss all your non-hardware-processed tracks to an Aux and just use the UA Delay Comp on the Aux.
I use this all the time to patch in a Lexi reverb unit. Works great.
Phil O
Post by Phil O »
Sorry if I'm getting OT here, but what is the difference between UAD's DelayComp and TrackAdv? They appear to do the same thing.
Phil
Resonant Alien
Phil O wrote:Sorry if I'm getting OT here, but what is the difference between UAD's DelayComp and TrackAdv? They appear to do the same thing.
Phil
DelayComp is for audio tracks and TrackAdv is for MIDI tracks
danny
Post by danny »
I'm not sure why you would want to compress drums OTB and then blend them with the dry versions in DP, but If I were going to do this, I'd just zoom into the sample level and line up the tracks visually, primitive that I am. It should be a really miniscule amount of latency if you're using analog processing OTB.
Dual G5 1.8, 10.4.8, 3GB RAM, SSL X-Logic 24 channel ADDA feeding RME card., MIDI Xpress, Liquid Mix, analog summing (Studer 902).
