Hi Folks,
Running dp 4.61 on a mac mini, it's working great.
I have Kontakt 2.1.1 loaded and having a good old time playing voices 1-16.
How do I access Kontakt voices 17-32? They don't seem to show up in DP as 1-16 do.
I recall SI had the same issue which was solved with a newer version, but I have the latest v. of Kontakt running.
I PROMISE I'll look at the manual too I'm just not sure which one to look at.
Fred
Accessing 17-32 voices in Kontakt
not a significant amount. Either way, the only other way to access 16 more channels is to have the standalone plugged through Bidule, which itself would probably take up more RAM than 2 plug-ins. 2 Plug-ins is really not that much of an impact. Also keep in mind that their are only 16 DP MIDI channels as it is.
BTW, I use 2 Kontakt plug-ins for my virtural orchestras, and it works fine.
More on Plogue Bidule here:
http://www.plogue.com/
DP 4.61 on 10.4.8
Powerbook G4 12" 1.5 ghz 1.25 gig
Kontakt2/GPO/VSL/EWQLSO Gold
I've actually forgotten but looking at "about this mac" it says:system6 wrote:What kind of mini? How's the performance?
Processor 1.5 GHz PowerPC G4
Memory 1 GB DDR SDRAM
Frankly, it works great. I'd say you can do anything as long as you don't overload it. By overloading I mean that when I run a loaded bank of polyphonic SI and then everybody is playing a lot (ie: full orchestra's worth of instrument) it'll start slowing down and/or breaking up.
But frankly, short of that it's terrific.
Fred
