Reccomended pci cage...
I know nothing about the pci cages except that I need one. Brand, source ect. I have a G4 dual 867 running DP5. I have two uad-1 cards and want to add two more. Any help would be appreciated.
Lenovo Yoga i7, 16RAM, DP 10.11, Waves analog modeled plug-ins, AmpliTube, Shreddage 3 Jupiter, Mackie HR824 Mk1, Tobii Eye gaze mini.
Yes, I do everything using only my eyes. #ALSsucks
Even when I'm new school I'm old school.
PCI Cage
Nobodys got anything for me? I know some of you guys are running multiple pci cards in a cage...A little help ova hea...Thanks
I do not use any UAD cards but a Dual 867 has 4 available PCI slots. I am not sure if there would be any power supply issues. I assume by "cage" you mean an external PCI expansion device. Keep in mind such a device will tap into the same PCI bandwidth as having 4 UAD cards in the G4.I know nothing about the pci cages except that I need one. Brand, source ect. I have a G4 dual 867 running DP5. I have two uad-1 cards and want to add two more. Any help would be appreciated.
I guess I am not sure why you need one when your interface is firewire based and the G4 has 4 slots.
Re: Reccomended pci cage...
magma makes a line of pci expansion chassis:arsis wrote:I know nothing about the pci cages except that I need one. Brand, source ect. I have a G4 dual 867 running DP5. I have two uad-1 cards and want to add two more. Any help would be appreciated.
http://www.mobl.com/expansion/products/pci_expansion/
however, your machine should have 4 slots available. what else are you running on the pci bus beyond the two uad-1 cards?
