PCI 424 audio wire - how many outputs
mircut
Post by mircut »
I am having trouble with audio wire output 2 on my PCI 424 card in my G5 dual 2 Gig. It doesn't work.
I see that there are 4 outputs on the card, but the DP manual says there are 3. I haven't been able to get any sound output from the 4th slot and am wondering if it isn't an audio output (even though it looks just like the others). I was hoping to use Audio wire 4 as a workaround for one of my 2408s. It does show up in DP4.61.
I thought if it is an audio output, perhaps the reason I'm not getting audio out is a cue mix routing issue. Any help is greatly appreciated - of course it's a holiday week. Sigh.
Mircut
giles117
Post by giles117 »
Uadio wire #4 works... Do you haev the latest drivers, etc....
I have 4 interfaces hooked up and they all work.
DP 6.02
Quad 3.0 Ghz, 8.0 GB RAM, 2 - 1TB HD, 5 - 500GB HD's (RAID)
MOTU HD192, 2408mk3, Microlite, UAD-1, UAD-2, Powercore, Lavry Blue AD/DA convertor, LA-610
Euphonix MC Control
29 years in this business and counting.....Loving every minute of it.....
mircut
thanks
Post by mircut »
I think I have the latest drivers - any other reason you think it might not be outputing audio?
Frodo
Post by Frodo »
With two audiowires connected, check to see if your host multipliers are set to 2...?
sndhse
Post by sndhse »
It should be set to 3. 424 counts as 1, 2408 -2, 2408 -3 etc...
John
mircut
host multipliers
Post by mircut »
Where can I find the host multipliers - I've never heard of that before...
Frodo
Post by Frodo »
Ah..
Setup > Configure Hardware Driver
This can also be accessed via the Hardware button on the Transport's horizontal pullout drawer.
mircut
Post by mircut »
thanks, I found it. But it still didn't work. Do the PCI outputs have to be in order? I tried skipping the problematic one but it didn't really change anything.
Frodo
Post by Frodo »
Yes. I'm not at my tower right now, but slot (socket) #1 on the card is the one closest to the ADAT sync port.
WSVP
Post by WSVP »
John
This is incorrect John. If only one 424 card is present buffer multiplier should be set to 1, as the system and MOTU view all devices attached to a single 424 or 324 card as one interface. The multiplier should only be higher than 1 if you are for example mixing a Firewire Interface like an 896 or third party device with a PCI-424 solution.
Make sure you have enabled all ports in the MOTU PCI Audio Setup.
Hope this helps
