DI or not?
- Obscure Object
DI or not?
just a quick question .... I have a cheap digitech multi-effects pedal for my guitar .... is the out of that kind of units line level? .... in other words, can i connect the out of the pedal directly to one of my line inputs on my traveller? ... or do i still have to use a DI on it?? ... thanx in advance
Her nose was not really a nose at all. It was only a beginning.
- mhschmieder
Well, for that matter, you can plug anything into anything and get some signal. The point isn't what works, but what is optimal.
I bought an Avalon U5 DI/preamp (mono) last year and have found it has made a 400% improvement in sonic fidelity for high impedance signals that I had previously plugged directly into a console or recording unit.
Any "class A" circuitry that is well-designed should achieve a similar purpose. I chose the Avalon over the Countryman or other floor-pedal-shaped DI's because I use it as my live bass pre-amp as well as a studio DI. That more than compensated for the extra cost.
- Obscure Object
