Thanks.
Yup, I do vocal comps this way and it works well (for the way I operate, at least).Anyone else working like this? Problems you see with this method?
I think I understand your question. If you have two "touching" or crossfaded soundbites and you need to move either in one direction or another then you'll need to select and move both of them if you want to preserve the edit.Is there a way to "lock" all edits so that when you drag a file, all the other files and their edits move with it?
Consider creating a new empty master take instead of a new master track, and then just copy and paste the selected segments using time range selections into the new take. It will save you a lot of time and will dimish track clutering.draudio2u wrote: I think fo this session I will record take by take in the same track, audition, then edit in a "destination" master track. This way we can keep the session rolling. While they break, I will edit, then we all review.
BTW, problem with sellecting all parts to move a soundfile and not loose other edits - what if you are recording an hour of music with a hundred plus edits? I hate zooming all the way out, dragging across all the sound files to sellect them, and then fin tune the original edit I need to tweak. Hey MOTU, how about a "lock down" button in DP5!?
Thanks for all your help.
