mach5 or sampletank
Posted: Fri Mar 17, 2006 9:20 am
by guitarsark
which is better and why?
are they similar?
for me, ease of use and sound quality are most important.
currently running dp4.6 on dual g4 panther
thanks.
Posted: Fri Mar 17, 2006 9:36 am
by stephentayler
Depends what you want them for.
Sampletank is a sample player and comes with a very broad range of its own sounds. It also has a very straightforward interface and good effects. It cannot import other manufacturer's libraries or your own sounds.
Mach 5 is a sampler, and although it comes with a few sounds, it is capable of importing countless other libraries. The best thing about it is that you can import and tweak your own samples and has very sophisticated tools for doing so.
I love and use both, so you need to decide what your own use will be.
Stephen
Posted: Fri Mar 17, 2006 2:11 pm
by mtec
sampletank 2xl can import ur own samples without problem. mach five has more editing capabilities.get both they are both great.
Posted: Sat Mar 18, 2006 11:32 am
by guitarsark
maybe i should get sampletank first, since it sounds a bit easier?
Posted: Sun Mar 26, 2006 9:28 pm
by Jeff E
Definately get Sampletank first. I went the other way... I have had Mach 5 since it came out. I imported all my sampleCell and Kurzweil sounds.. And others. But the Sampletanks just seems to work easier for Right now sounds. I have not gotten into programming with ST and making new sounds but use Mach 5 for that. It is pretty powerful for that. I wish sample companies would make more for mach5, but thats a developer issue with MOTU.
Jeff
Posted: Mon Mar 27, 2006 1:16 am
by 3over3
Jeff E wrote:Definately get Sampletank first. I went the other way... I have had Mach 5 since it came out. I imported all my sampleCell and Kurzweil sounds.. And others. But the Sampletanks just seems to work easier for Right now sounds. I have not gotten into programming with ST and making new sounds but use Mach 5 for that. It is pretty powerful for that. I wish sample companies would make more for mach5, but thats a developer issue with MOTU.
Jeff
Can you make your own sounds in SampleTank at all, or do they have to be part of an existing library?
Re: mach5 or sampletank
Posted: Tue Mar 03, 2009 8:56 am
by Martini Hill
Importing your own samples into sampletank is extremely buggy at best. If you are lucky to get a few imported you will have very little editing capabilities.
Posted: Tue Mar 03, 2009 1:43 pm
by 3over3
... now that's a quick answer! Three years, less 24 days!
Posted: Wed Mar 04, 2009 11:35 am
by Martini Hill
I aim's ta please!
