The free VI's/plugs list.
Synful is now free
Apologies if I'm not in the correct topic branch but this is pretty cool news.
Eric Lindemann has decided to make Synful free. A donation is requested "to keep Synful alive".
Synful has a nontrivial learning curve and working with the various latency-avoiding tricks is not completely simple but I still think that it gives pretty much anyone else a serious run for their money when it comes to realism.
Check out the demos. The Beethoven quartet (one of my favorite pieces as it happens) is very compelling.
Synful comes with demo files and stems of several tunes, including the Beethoven quartet (e.g., there are DP files with the demo tracks).
Very much worth checking out.
https://www.synful.com/
Re: Synful is now free
I moved it to the "FREE" topic since seemed perhaps more appropriate. Thanks.
iZotope Nectar Elements 3 free
Looks like iZotope is giving a way Nectar Elements 3 for free.
https://www.izotope.com/en/products/dow ... ments.html
You just have to create an account at iZotope if you don't already have one.
8 OhmForce plugs,: retired, updated to AS, given away for free
A French developer called Ohmforce retired 8 of their plugins.
[EDIT: The status of these plugins as "AS Native" was reported on another forum, but it is apparently incorrect or at least not the case for all of them. I have not checked them.]
https://www.ohmforce.com/plugins
You have to create a free account. The webpage has a cute phrase:
"Legacy Plugins; Free on your ohmforce account, Also free of support."
Heavyocity Staccato Brass
Re: 8 OhmForce plugs,: retired, updated to AS, given away for free
Wow! THIS is did NOT know. I just assumed they would require Rosetta so I ignored this before. I'll have to check them out!stubbsonic wrote: ↑Mon Aug 07, 2023 11:09 amBut in one of the most classy moves ever, they updated them to AS, before retiring then freebie'ing them. Well done, Ohmforce!
I'm not sure this is correct. I just downloaded two of them: mobilohm and symptohm and dragged the AUs into the Components folder and they showed up as "Intel 32, Intel 64" in PlugInfo. I already deleted Symptohm, but you can see below that Mobilohm is not Apple Silicon native.stubbsonic wrote: ↑Mon Aug 07, 2023 11:09 am But in one of the most classy moves ever, they updated them to AS, before retiring then freebie'ing them.
I can't confirm that they are AS compatible, either. Also. I couldn't find any documentation to confirm it.James Steele wrote: ↑Fri Aug 11, 2023 2:25 amI'm not sure this is correct. I just downloaded two of them: mobilohm and symptohm and dragged the AUs into the Components folder and they showed up as "Intel 32, Intel 64" in PlugInfo. I already deleted Symptohm, but you can see below that Mobilohm is not Apple Silicon native.stubbsonic wrote: ↑Mon Aug 07, 2023 11:09 am But in one of the most classy moves ever, they updated them to AS, before retiring then freebie'ing them.
Re: The free VI's/plugs list.
I didn’t try them. I have really too many plugs to mess around with any more plugs that aren’t native Apple Silicon. I wouldn’t be surprised if they work with Rosetta.
Also, the manner in which you must manually install them bothered me. For example, they have you put the Preset folder directly in the Library folder which doesn’t quite follow the usual conventions.
Hz Box
Hz Box is a free plugin that has resonators and few modulation things. It's probably akin to having an acoustic resonator and/or cab IR. It has a few other little features. There's a long video to describe it. The manual is pretty decent, as well.
https://higherhz.com/hz-box/
They also have a free delay:
https://higherhz.com/hz-delay/
And another multi-effect thingy:
https://higherhz.com/hz-multiplier/
Wave Alchemy Dawn (EMT 250 emulation) - Free IF....
So I got an email from Wave Alchemy. If you have any of their other products, like Glow or Radiance, then you should have a free download of Dawn in your user area. Just a heads up.
https://www.wavealchemy.co.uk/product/dawn/
AS was shown on a misleading article on another forum. I corrected my original post. Can't do anything about the subsequent quotes.James Steele wrote: ↑Fri Aug 11, 2023 2:25 amI'm not sure this is correct. I just downloaded two of them: mobilohm and symptohm and dragged the AUs into the Components folder and they showed up as "Intel 32, Intel 64" in PlugInfo. I already deleted Symptohm, but you can see below that Mobilohm is not Apple Silicon native.stubbsonic wrote: ↑Mon Aug 07, 2023 11:09 am But in one of the most classy moves ever, they updated them to AS, before retiring then freebie'ing them.
Re: iZotope Nectar Elements 3 free
Requires Rosetta 2 with AS Macs.James Steele wrote: ↑Fri Aug 04, 2023 3:03 pm iZotope Nectar Elements 3 free
Nectar 1 used to be my go to quick-and-dirty plug for pop vocals. Nectar even had an intuitive pitch tool that could tune vocals more naturally than any other that I’ve tried before or since. Unfortunately, that component was replaced by Melodyne with Nectar 3 and I hardly use it anymore.
I’ll turn my users onto this and see what they can do with it. Thanks for the heads up.Nectar Elements features
Vocal Assistant:
Get polished vocals with AI
Easy-to-adjust sliders let you fine tune your sound
Intuitive Control
Soundiron Rainsong - FREE
https://soundiron.com/products/rainsong/
NOTE: It will appear in the Libraries section in Kontakt. Just be sure to look inside the Custom FX directory in the library, as there are specialized instrument inside that directory.Rainsong is a free instrument library for Kontakt, created from a variety of natural rain ambiences and raindrop sound effects, crafted into playable sound-designed synths, pads, atmospheric soundscapes and percussive sfx. It's full of playable muscial elements, as well as useful sonic elements and foley for videogames, animation, film and songwriting.
I have what seems to be good news, Mike. I just ran PlugInfo and it looks like iZotope updated Nectar 3 Elements to native Apple Silicon. Check it out:
