Page 7 of 7
Re: new driver version
Posted: Wed May 13, 2009 7:11 am
by 1nput0utput
Mark S wrote:FWIW: the firewire standard is a MAC standard. A number of us who have had to dig into this have found from sources way more in the position to know that the standard as written is by MAC inspecific in a crucial area. This allows for performance variances between manufacturers that can still be considered within the standard. It also allows for Microsoft to write a 1394 driver that is 'in the standard' but allows for variances of results.
Actually, the IEEE 1394 standard was developed by a working group that consisted of representatives from Apple, Sony, TI, Sun, Samsung, and others.
http://en.wikipedia.org/wiki/FireWire#H ... evelopment
http://grouper.ieee.org/groups/1394/1/index.html
In fact, if you check the minutes from the February 1996 meeting of the working group, you'll find this list of attendees.
  • The following people attended the meeting:
    Dave James, Apple
    Peter Johansson, Congruent Software
    Nobuo Furuya, NEC
    Kaz Abe, NEC Systems Lab
    Ron Laborde, PACT
    Arshad Hasan, Samsung Info Systems
    Ed Carmona, Seagate
    Horatio Lo, Seagate
    Andy Jones, SGS-THOMSON
    Colin Whitby-Strevens, SGS-THOMSON
    Dick Scheel, Sony
    Bill VanLoo, Sun Microsystems
    Alan Wetzel, Texas Instruments
Posted: Wed May 13, 2009 8:31 am
by TheRealRoach
APAD,
So the common thread seems to be that nothing past 915 has worked, and thus, multi-cores don't work either... In other words, anything newer than 5 years old doesn't work in its stock configuration...? The newest chipset that you mention is the 915, which - so far as I can tell - came out around 2004.
On a sidenote you mentioned that you had eight functioning stock systems, but you only mentioned four. Could you describe the other four in the same way? I'm curious as to whether the other four are 915 or earlier as well.
Edit: I think by writing "(4) IBM Thinkcentre S51" you were indicating that you have four of that model?
Posted: Wed May 13, 2009 10:09 am
by APADRecordings
That's right. Four of the 8171. They work so well and are so inexpensive ($89 - $130) and fit in a 3.5 inch rack space - just right for location recording.
I don't know about newer systems as the only ones I've tried are the Intel I listed (although I don't know how old it is) and the IBM Thinkcentre M55e, which is a dual core. The IBM was a 3.4 GHz system - a real performer - but it won't do Firewire.
Posted: Wed May 13, 2009 2:40 pm
by TheRealRoach
APAD,
The information you provide is interesting, and it would be telling to find out what other fully functioning "stock" setups exist. This will probably never happen though as most active online users are those who are having problems or have had problems in the past... not the ones who are enjoying simple plug and play success like you.
In the end though, using 4+ year old single-processor systems <915-chipset (in other words, avoiding anything built in the past four years) doesn't seem like any better a solution than making use of new systems that may require a manual 1394 bus controller driver change.
Based on our discussion, any of the following could be true:
(1) - for the past 5 years mobo/chipset designers (nVidia, gigabyte, intel, asus, and many more) all failed to recognize that there were some serious issues with their systems' design and chipsets.
(2) - MOTU fails to develop drivers that function in consistently with any mobos and/or chipsets developed after 2004 or 2005.
(3) - MS fails to keep up with providing drivers that function properly with modern protocols (like 1394).
What I know is that there is written documentation by MS stating very clearly that they messed up 1394 once in XP SP2(http://support.microsoft.com/kb/885222), and again in XP SP3(http://support.microsoft.com/kb/955408). I also know that for many users, flipping back to SP1 drivers fixes the issue as easy as flipping a switch. This makes it pretty clear to me that MS has something do with it.
But there is one interesting thing that I noticed: your 915 chipset (the "newest" successful chipset in your systems) was released June 2004 (http://en.wikipedia.org/wiki/List_of_In ... 4_Chipsets) while, XP SP2 was launched in August of 2004 (http://en.wikipedia.org/wiki/Windows_XP) only 2 months later.
Here's my hypothesis (which is an amalgamation of your theory, and mine):
- <Aug 2004 MS was working hard trying to ensure FW worked great, and did this by supplying drivers. At the same time hardware manufacturers were doing the same.
- >Aug 2004 MS launched SP2 which crippled firewire from 400mbps down to 100mbps, thus making USB look like the superior protocol to the unknowing user. Hmmmm, why would they do this? The conspiracy theorists (hah) claim that firewire (an Apple trademark) was crippled this was done to make USB look better. Remember USB3.0 was just launched in Nov08.
- MS released a hotfix to patch up the speed problem after complaints, but it's probably safe to assume that the foundation of the 1394bus controller driver hasn't truly been updated since the SP1 days, when your 915 and earlier were designed. It's only received bandaid after bandaid. This would explain why SP2 and SP3 continued to work with your older system's firewire devices: the SP2 and SP3 are only truly compatible with the old hardware from the SP1 days. This would also explain why third-party AVT drivers have been successful for some users' new systems: it's a total rebuild that addresses modern designs. It would also explain by reverting back to the original SP1 drivers is successful for some users' new systems: it's not bloated with fixes and other fat.
Posted: Wed May 13, 2009 3:43 pm
by APADRecordings
Your hypothesis sounds good to me.
I wasted so much time trying to make the Dell 830 and the IBM M55e work and the embarrassment of messed up recordings, some of which could not be redone, that I finally said, look, I'm in the recording business and I have neither the time nor the resources to try to figure this mess out. I'm going back to equipment I know works. Even though it's older firewire 400 is not that difficult and I'm rarely dealing in more than 12 tracks.
Eventually I hope it all gets worked out. Firewire, being isochronous, is much better for recording than USB, being asynchronous, can ever be.
My son is working with some new systems about the size of a standard book, in the $300 price range, that he thinks are going to be dynamite for those of us in recording. He says give him six months to work out the FW issues. My fingers are crossed!
Posted: Wed May 13, 2009 4:27 pm
by APADRecordings
These little "bricks" Peter is working on use embedded XP which I think MS has agreed to support to at least 2017. They have Gigabit Ethernet, use solid state drives and passive cooling. No moving parts. Passive cooling is fine because total power consumption with the special dual core processor is well under 5 watts. My hope is that we'll be able to put the Traveler and one of these things in a small cabinet and end up with a self-contained recorder.
What a beautiful thought: a computer that is instant on, uses only as much OS as is necessary and all residing in ROM of some type. Unfortunately these don't come with FW but that's what Peter is working on.
It may be of interest that the new F35, Joint Strike Fighter, uses FW 1200 for all controls. Good stuff!
Posted: Wed May 13, 2009 8:49 pm
by Mark S
APADRecordings wrote:Your hypothesis sounds good to me.
We've all wasted too much time trying to make things work. And so far, I'll agree that firewire is superior to usb. One of the most frustrating things has been the lack of interest on the part of MOTU on all this. So we're all stuck with doing the research and trying the possibilities before reporting back. Like you I'd rather be recording than playing with gear but after I've burned the money to get what I have what real choice do I have?
Ultimately we are in the same boat trying to say the same thing more or less.
When your son figures out that new system I hope you give an update. My vote would go with small and portable, able to do 16 tracks at 96/24, and can sync two firewire daisy chain units,... Seems so small of a request, really.
peace out
Posted: Thu May 14, 2009 3:58 am
by reflective
Posted: Thu May 14, 2009 7:54 pm
by Mark S
and what does that have to do with this conversation?
Posted: Tue May 19, 2009 8:39 am
by dare
...and what all of this has to do with messed inputs ??? This is very marginal driver error which isn't fixed for the whole 3 months from the initial release! Is it so hard to rename inputs/outputs in the driver ? And if it is a chipset issue, then how came WDM is correctly mapped and ASIO is not ? It is an obvious programmer's error! MOTU is one of the few interfaces that has full true 64bit support and that is the reason why I haven't sold it yet! :x
