Great! That's a relief. I do NOT like using Altiverb AU in DP8. It misbehaves badly, not letting you start or stop a sequence without clicking back over to a DP window first. Also, the selector window with the list of all the IR's (and a picture of each) will not close with a keyboard command, plus it stays in front. You cannot access the controls on the main panel when the selector is open. I'm almost positive that i used to do that on the MAS version.labman wrote:Aram @ Audioease says they are working on 64bit MAS.
Also, the AU Altiverb apparently does not recognize a single one of my MAS Altiverb presets. I've got about a dozen presets that are very important to me. I can't even figure out a way to reconstruct them, except for possibly opening DP 7.24 and switch back and forth between them while I meticulously copy each setting. I don't even know if that's possible.
In NON-Altiverb news:
• I'm having a lot of trouble with DP8 recognizing some keyboard commands. For example, when I want to quick-group some tracks by holding down the W key, it only works occasionally. Seems that I have to reboot DP to get it to work.
• DP isn't recognizing COMMAND-A at the moment. (Select All) That's one of my most important commands, and it's not happening! Again, I think it's intermittent, but DP is running as I write this, and that is NOT working.
• Plugin windows that I leave open all the time used to open when I reboot the sequence. In other words, when I start DP and open the file, the plugins I left open when I last quit should open back up where I left them. Instead, an empty plugin holder opens, without even a plugin assigned to it.
There have been some other things, but I haven't kept the best notes. As I think of them, I'll add them. Please do not take my comments as negativity, I'm just pointing out places that need work in this brand-newly rewritten version of our old familiar DAW.
Almost forgot: if anyone else experiences these same problems, please corroborate here. Maybe I just need to reinstall DP8.
