Good to know Gary! And I've been WUP'ing my Waves plugs as they get towards expiration. Doesn't really cost much and you get Vouchers!ghobish wrote:AnthonyS wrote:I doubt MOTU will screw us over with the upgrade, and even if they haven't addressed the Waves version 9 compatibility, I'm sure there will be a patch forthcoming.
DP8 will not need a "patch." The whole issue is Waves 9 is Cocoa and DP7 is not. I don't see this as a Waves issue at all- were they supposed to wait until MOTU modernized it's code before upgrading their line to 64-bit?
And re WUP: As noted earlier, Waves revised it's system so that now no matter how out of date you are, it will be a max of $200 to get up-to-date, and that includes all of the newer plug-ins that have been added to your bundles since the last time you were up-to-date. Not a bad deal at all.
Waves 9 NOT COMPATIBLE with DP!
Re: Waves 9 NOT COMPATIBLE with DP!
MacBook Pro 15" 2G QuadCore i7,8G RAM, 20"Intel iMac 2.4Ghz , 4G RAM.OSX 10.8.3 on both, DP 7.24, MOTU 828MK3, AudioBox 1818, KRK Rokit 6G2, Omnisphere 1.5, Komplete 8, Amplitube 2&3, SampleTank, Sonik Synth2, SampleMoog, SampleTron, Ivory 2, Philharmonik, EWQL MOR, SC, SOG, SD2, Reason 6, Waves, McDSP, Slate Digital VCC, FGX, Sound Toys.
what's the trick to get Waves 9 not to crash in DP 7.24? I open an effect , close it , open the next one & bam , crash ...DP 8?????
thanks !
thanks !
Mac Pro 4,1 2.66 GHz Quad Core, 16GB Ram, OSX.7.5, Dual Cinema Displays -ATI Radeon 5770, Motu 896/828MK II DP 8, Waves v9
- ghobish
Are you updated to 9.1? Although not officially supported in DP7, it is working fine for many.tommypenngotti wrote:what's the trick to get Waves 9 not to crash in DP 7.24? I open an effect , close it , open the next one & bam , crash ...DP 8?????
thanks !
Gary Hobish
A. Hammer Mastering & Digital Media
San Francisco, Ca
http://ahammer.com/mastering
Mastering: Mac Studio M1 MAX 2TB SSD, 64GB RAM, 32-core GPU, OS 12.6; DP 11.22, Waves, Izotope RX10 Advanced, Alloy, Nectar, PSP stuff, Plug-In Alliance, Metric Halo ULN-8 MkIV, Euphonix MC Control & MC Mix, Presonus Central Station, and (still) no air conditioning (but at least now there is airflow)
Annex: Mac Pro 2010 5,1 3.33GHz 12-core, 80GB RAM, 10.14.6, DP 11.22, Metric Halo ULN8 MkIV, MOTU 2408III
San Francisco, Ca
There is no trick. Waves 9 does not officially work in DP7.24.tommypenngotti wrote:what's the trick to get Waves 9 not to crash in DP 7.24? I open an effect , close it , open the next one & bam , crash ...DP 8?????
thanks !
Let's get a reality check here, shall we? Aside from a few questionable
"new" plugs, there is nothing in Waves 9 that is essential to music production. In fact, I can't even think of a reason to get any of the "new" plug-ins.
DP 7.24 is not 64-bit. Therefore, no advantage to running a 64-bit plug-in
in DP 7.24.
So I gotta ask - why are you even trying to run Waves V9 in DP?
http://www.davepolich.com
