Shooshie wrote:I always erase my old versions after installing the new upgrade. Usually, I wait until I know it's going to work. This time, I just optimistically erased DP 4.61 before installing DP5. I haven't regretted that, though it would be nice to compare CPU headroom in the two on identical files. I probably have a backup copy on DVD, but that's not important enough to me to go looking for it and copy it back over. I actually did an "un-install" of DP before I installed DP5, just to be sure that everything was compatible and fresh.
I think DP5 is a little like DP4.0. I'm guessing that it's got some major changes under the hood, and that this is our public beta. version 5.1.1 ought to be the one that makes us finally sigh in relief and say "ahh... this is why I use DP." Well, at least, I hope. I know I sure don't like this sudden quitting stuff. Even though I save often now (and I had gotten lax about that, lulled by the stability of DP 4.xx), it's still a hassle, takes time, and you always lose something. But I've seen it many times before. It's always brief, always gets fixed in another round or two. And this is very intermittent. Very rare. It's nothing at all like version 4.0 which crashed when you clicked on lists, and things like that.
I gotcha..
I always save all the time and think that I save so much, it is why I always have to re-build larger DP files after version 32 or so...they end up corrupting. Ever had that happened?
I wonder about the thoroughness of DP's un install....
I recall a more thorough way from a tech support email ..
here it is:hope it helps if help is what you even need..lol
Hello,
Follow these instructions to perform a clean install:
1. Go into the "users / (your username) / library / preferences" and
move the "Digital Performer" folder to the trash.
2. Press Command-F to open the finder's find function.
3. Add a Criteria - Visibility. Set Visibility to all (visible and
invisible items).
4. Search everywhere.
5. Select the drive that DP is installed on and type "AUTH" in the
search
field. You should find a file named "AUTH-Digital Performer 4.0". Move
it
to the trash from the File menu, then empty the trash.
6. Insert the DP4 CD into the computer and launch the installer. Select
"Uninstall" from the install dialog and complete the operation.
7. Once uninstall is complete, restart the computer.
8. Go into the "Applications / Utilities" and open Disk Utility.
9. Select your system drive from the list on the left. click on
the First Aid tab.
10. Once inside the First Aid tab, click on Repair Disk Permissions.
This may take a few minutes.
11. Once complete, install DP4 from the CD.
12. Once install is complete, launch DP with the CD in the drive, then
enter a name at least 3 characters in length and the keycode.
13. Once DP has loaded successfully, you may quit it and install any
necessary updates. The "DP4.12 Update Install" as well as "DP 4.12 MAS
and AU support bundle Update."
Peter
MOTU Tech
